I can't see the harm in doing a few courses, most material has its quirks that need to be addressed to get the best out of it which will be pointed out on the courses. Expecting K Rend to apply like Parex, or Weber to apply like K Rend when using them for the first time is where a lot trip up.
Parex mixes quickly and applies like butter generally but has a lowish cement content and "only" a 10 year warranty. (Not sure if the warranty has changed recently though, I need to check.) Parex is definitely the applicators favorite.
K Rend Silicone gear needs a double mix and a stronger arm but you get a higher silicone modified cement content along with a 25 year BBA cert and punters like the sparkly bits. Applicators should be able to charge a few quid extra a sq m to the private punter due to this. The K1 range looks to address some of the extra application requirements by lowering the cement content and therefore the products overall strength and currently there's no silicone version but that will change soon I believe.
Weber is somewhere in the middle, no silicone but a full 25 year BBA cert and there's even a few sparkly bits if you look hard enough
