Do you use stop beads around the cills or form a soft joint using foam to allow for expansion?
on our systems we fill the joint with high module mastic.
Alright lads new to this forum business. Got a fair size KRend job which is split into 6 panels. Each panels been sbr'd onto the brickwork followed by a backing coat then a top in pewter grey. The problem is when we come back 12 hours later to rub up there's a few hairline cracks in different places over the panel. Anyone got any ideas? Cheers Munners
Cracks.....
I have just rendered 90+ Sq/mtrs onto block work and had cracks on all south facing walls. I didn't use any mesh but I did use the K-Rend TC product (which is the same as thistle bond-it). This problem occurs even with Webber so it isnt the product and it also happens to sand/cement
When the mix was 'too wet' it cracked lots, where the mix was on the 'dry side' there was only the odd crack.
I experimented with ways of repairing it. I found that getting on it the next morning after application is best. What I found worked for me was wetting the crack with rad brush leave the water to work in a few mins then dampen the whole area around the crack with a sponge float. Then get a handful of dry k-rend straight out the bag & just throw it at the crack and rub it around the area with your hand (wear gloves!!) you will find it fills the crack and blends well. leave to dry for a bit and with a damp sponge float just go over it.
I think the cracking is caused when the surface dry's creating a crust, when the render behind drys it goes tight and stresses the top surface, causing it to crack. One comment on here mentions the walls being a thermal store and this is very true and can cause the same effect. The wind will dry the surface fast also.... This is a very common problem!
One thing I have found which helps better than anything is get your timing right before you flatten off.
If you spray on: leave the render rough till it is nearly dry before you rule off with straight edge.
If you apply by hand: leave the surface broken so it can dry slightly before you close the face with your trowel.
dry is better than too wet... you can always dampen down a wall if it is too dry using a sponge float, if you need to.
SBR...
What you did with the SBR is a fine but remember when you use SBR you create a barrier which stops moisture. Usually the moisture in render will be 40% absorbed through the block work itself but if it has SBR on it cannot do this! meaning that the render slips around and also stays wetter longer. Which I mention above causes cracking... I hope this is helpful
This is not written in stone, I am not preaching! it is just from based on my observation whilst rendering
Cracks.....
SBR...
If you mix it twice it comes out lovely and shouldn't slump, very labour intensive though
This can't be emphasized enough with the FT. All polymer renders will treat you better with a good long mix.
Is ft actually classed as a polymer render though ? Is the content at the percentage level.
Its nothing like powerwall or m1 that have polymer render classification.
Got a wp job on. Can't be sprayed wp so will be doing 7bag mixes in the barrel. Mixed twice as before.
Anyone using krend hand app?
If you ever try egrade but hand app it? Its much nicer gear to work with and still silicone
Yeah, hand applied 2 pallets of it after machine was sold. Pretty nice to put on. Then had to put wp ivory on and it was like where's the plasticiser , it was dead..Is ft actually classed as a polymer render though ? Is the content at the percentage level.
What's the difference with normal and egrade?
Hi friends I'm new in this side I'm builder we done k rend 4 weeks ago proper my Jamaican friends he have more then 20yrs experience now new k rend hair line some main front wall so plz give me suggest what I do my name Karan Singh frm west london
The difference is amazing in quality I agree.for k rend to suggest to fill cracks in with dust, just about sums them up.
that's k rend for you, pot luck rendering.
It is a viable option with the first 14-24ish hours of application, with all renders.
I realise you may have had a bad experience but there are applicators out there that swear by the stuff and do actually enjoy applying it.
The silicone range isn't designed to be the easiest to apply on the market, it never has been but the private punters get attracted to the word "silicone" rightly or wrongly. Where most applicators go wrong is charge the same labour rate to stick the stuff on as the easier basic renders then get their knicker in a twist when they aren't in the pub by four.
If a punter wants silicone be straight up, tell them the silicone makes application more complex, mixing time is effectively doubled and you will have to put more effort in to get a good spread and you want a few extra quid a metre. Now you have the extra cash as punters will pay it in my experience make sure you read the datasheet and do what it says and approach the job with a different frame of mind.
Getting a 25 year BBA cert ain't easy, the gear is tested to within an inch of its life in the lab and you need real life examples of the product doing what you say it does. There's a reason others only offer 10-15 year guarantees.
If your having to fill out 'shrinkage cracks' with dust it is an inferior product.
Your teaching me to suck eggs pal,
Its nothing to do with ease of application.
Make that multiple bad experiences with k-rend. Be it bad batches to shrinkage etc it wasn't an isolated incident and the back up service is poor. There are far better bagged renders out there I've used everyone one out there on every differnt sort of project, it's not just me saying this, look at other posts on here, we used to use a lot of k rend but don't use any now.
Im fully aware of how BBA's work I've been involved with render companies at a decent level, I also employ quite a few lads both on the books and subbies and spend over a £100,000 a year on render so I know what I'm dealing with, I'm not working out the back of a van doing the odd wall with the gear. The k1 has been a nightmare for K rend as it has had a lot of bad feedback, and recalled gear.k rend want my business, I've got 2 full pallets of k rend given to me for nothing by k rend direct and I've resisted the option of using even though it's for nothing, that for me tells the story.
Is he a salesman?
What a surpriseYeah, he's one of their area reps.
