Hi all, I’m new here.
I’ve searched over 50 threads and can’t quite find a definitive answer.
I have a large dense block retaining wall to render ~1.6m in height and 17m in length
The wall currently has no means of damp proofing against the ground behind nor a dpc but will be fitted with weep holes and gravel backfilled for drainage. A fitted land drain pipe is also a possibility but unsure whether it’s really needed alongside weep holes.
It hasn’t yet been backfilled so access is available.
I’m looking to apply a coloured silicone render such as K-rend to the wall. K-rend specify that their render is waterproof due to the its silicone properties. Do I need to add a damp proofing membrane to the rear of the wall when using K-rend? Are there any advantages or am I wasting time and money?
