K REND, why does it split ?
Did you spray it mate and did you serrate it before levelling? Not a lot of body to HPX as its mostly adhesive so it goes on thin on CP board it'll slide if applied too thick and / or you trap air which doesn't get removed. Trapping air and then slipping tends to be a problem for the sprayers only if you don't serrate. Whats the reason for HPX anyway, HP12 may have been better depending on what you are doing?
You try putting Maite on in a thick coat on CP board with a quick spat. Good luck.
That’s how not to apply maite mate
I think maite is one of the best basecoats out there if im honest, apart from tools getting hammered.
I did serate it, it happens all the time with krend apparently. Never seen it with parex or weber
