Runswithscissors
maybe we will organise an airless day again @knauf @Runswithscissors
Hi Danny
Give Clive a call, talked to him about this last week......
It's a recurring theme, BG do it all the time, so did extra time and even speed skimJust watched the video why do knauf nearly always get somebody to demonstrate the materials that doesn't look comfortable using them
Serious question ,what is airlessHi Danny
It's a recurring theme, BG do it all the time, so did extra time and even speed skim![]()
Airless spray atomizes, or breaks up fluid into small droplets without the use of compressed air. In an airless system, fluid is pumped under high pressure through a spray tip. The tip size and pressure is what determines the material flow rate. The tip also creates the fan pattern.Serious question ,what is airless
A guy on Facebook group charges £9m2 supply and fit!!We got some big ceilings we're thinking of trying this system. How does it compare on cost per metre I think it would suit the bigger areas as nobody likes to see a joint
We having all this again lol...its really moved fward in this last year since we last spoke about it!
It will be a difficult sell, when you see how much time and effort and going back and forth some people do to buy a stupid trowel for 40 quid, they will never invest in a machine for 5k to spunk some finish on the wall.We having all this again lol...its really moved fward in this last year since we last spoke about it!
DONT USE IT. IT IS WITHOUT DOUBT THE WORST JOINTING COMPOUND EVER!!!!!!!!Anyone know the drying time of knauf fill and finish? Is it 24hrs?
I got told it's ideal for patching little imperfections and quick drying but nobody could supply it on a short noticeDONT USE IT. IT IS WITHOUT DOUBT THE WORST JOINTING COMPOUND EVER!!!!!!!!
Belmore sell it and you'll get it the next day. Cheap too. It goes very hard, that's why it's a t**t to sand. I dumped two new buckets in the skip yesterday.I got told it's ideal for patching little imperfections and quick drying but nobody could supply it on a short notice
I need something what dries quickly and easy to sandBelmore sell it and you'll get it the next day. Cheap too. It goes very hard, that's why it's a t**t to sand. I dumped two new buckets in the skip yesterday.
Not yet GaryDid you try that Bagar stuff tony
Easifill then.I need something what dries quickly and easy to sand
I've been using easyfill takes ages to dry thoEasifill then.
Siniat G Tec Smartmix is nice
Or easi fill 20.Even easyfill 45?
Both sets quick 20min and 45 min, but drying time still 24hrsOr easi fill 20.
Even easyfill 45?
Your work that bad lolI've been using easyfill takes ages to dry tho
Can't deny it, I have my belt sander serviced regularlyYour work that bad lol
I meant 20Even easyfill 45?
Yes that's what I'm doing unfortunatelyI meant 20See what you mean though zolco it's cured but not dry.
How about force drying with a heat gun?
Good info cheersAirless spray atomizes, or breaks up fluid into small droplets without the use of compressed air. In an airless system, fluid is pumped under high pressure through a spray tip. The tip size and pressure is what determines the material flow rate. The tip also creates the fan pattern.
type of plaster![]()
Guys, it is very easy to sand, very little pressure required, also easy to patch with.On the video it said it was easy to sand. How tough is it compared with multifinish?
Danny, would be happy to arrange some dates in the new year.Hi Danny
The office lol
yup... the room I go to work and answer the phonewhen not in that room I am not working
a work life balance is essential
