Another little bit of advise from a plasterer who doesnt do my job "properly" apparently ......beside the other costs and unnecessary work you might embark on also worth" bearing "(not load just in mind) when the half tonne of crap gets kicked down part of the tops of the wall might as well, which will probably lead to them being stripped back to brick as well..
Not many builders will advise you about that they will inform you of the spiralling cost raising while they are on the job...fact
Aha! You are Cassie and I claim my ten pounds. I deduced this by:-
1) Your refusal to read the posts or links backing up what I'm saying.
2) You counter arguments I've never made.
3) Drama queen responses.
4) You put 'fact' at the end of an opinion hoping that doing so will make it true.
5) You've illustrated your point on a discussion about first floor (into loft space) ceilings using an image of a ground floor ceiling.
6) You describe work you don't want to do as unecessary.
7) You say that I've described you or anyone doing it as not doing your job properly.
P1ss taking aside, surely you can appreciate that if you explain the pros and cons to a customer they can decide? This means that you look more professional and knowledgeable to a customer. If they go for the additional work involved you have a longer job and earn more money. If they don't you take the quick option at no risk to yourself as they've made the decision with all the information you provided. Where is the problem with that?
Regarding your last assertion that you claim as a fact when it's merely an opinion. I can't speak for other builders, only myself. I can say with my hand on my heart, and the two people who I've worked with on the forum can back this up for the jobs they worked on, that I have never once increased the cost of a job to a customer.
I'll also go to the trouble of explaining why and how that is so. When I quote for a customer they are made aware of any choices they may have. Once those choices are made I provide a quote, never an estimate. If I have missed something, or not taken into account a factor affecting the work that's my fault not theirs, so I bear the cost. I do this because I'm confident in my abilities. I have been bitten on a couple of occaisions, not dramtically, but why should a customer foot the bill for my mistake or oversight?
Obviously if they add additional work during the course of a job then they pay extra. Before they do they are provided with a cost to do the work in writing which they can accept or not as they wish.
