Stress Relief in Render Around Openings to Avoid Cracking
Weber recommend the insertion of Weber standard meshcloth, or alkali resistant fibre mesh,
to areas of typical stress points in the construction, i.e. above and below all openings such as
windows and doors and at horizontal junctions of dissimilar substrates e.g. ring beams.
This is good practice and should be included in tender documents and technical
recommendations for all Weber Monocouche products and weber.rend OCR.
Process
Embed the mesh into the first pass of the render ensuring that it is not in contact with the
substrate. (If using weber.rend aid key coat it can be embedded in this application.)
Cut the mesh into a strip that will extend past the junction or point of weakness by 200-
500mm. Press the mesh into the fresh render evenly with a trowel or spatula and then over
lay with further render to encapsulate the mesh. Please see enclosed drawing. The mesh
can be ordered with your Weber renders through your normal stockist/merchant.
There you go buddy @
keithuk
