This is my point with Weber. The Caribean cat told me to fully mesh the rend aid then stress patches in the mono and any other weak area. Then the next day he said fully meshing the rend aid is pointless being so thin? Mesh in the mono is better done?
Well i can see that to a point although i am generous with rend aid and have enough on top of the mesh to get a scratch. I do not stipple as quite often the stipples come out on the surface of the mono.
As to having the mesh near the surface of the render I disagree. More like 1/3 in from the surface. I regard the 4mm mesh to small a hole 5mm being better like Prorends. The mesh being near the surface leaves very little thickness on the surface and being so small holes it could be a thin layer of render on a sheet of plastic especially if you are bit late being wet on wet.
