Wish I cud give that a double funnyAnd plasterman told me flynny is racist and only goes down on black men
I got told that as well lol...i don't even know y people are coming out with other stuff tbh
So your telling an experienced plaster how to mix and apply plaster? I honestly don't think the problem is inexperience if you was to believe the initial post. If this was done by a chancer o think the thread would be is this acceptable? Sad how you would rather blame basics rather then believe it could be the plaster? At least my opinions are not biasedAll the info is there.
Tips and even how to plaster
Link Removed
I once seen a curtain blowIve also seen fresh paint peel away in a strong breeze.
No experienced good spread rings there boss up flapping and getting his knickers in a twist wen there ceiling starts to peel on a hot summers day with the window open..clue is in the pic its rite above the windowSo your telling an experienced plaster how to mix and apply plaster? I honestly don't think the problem is inexperience if you was to believe the initial post. If this was done by a chancer o think the thread would be is this acceptable? Sad how you would rather blame basics rather then believe it could be the plaster? At least my opinions are not biased
So say it happens to you tomorrow are you gonna blame the weather?No experienced good spread rings there boss up flapping and getting his knickers in a twist wen there ceiling starts to peel on a hot summers day with the window open..clue is in the pic its rite above the window
Ye if I was skimming sumat with a warm breeze blowing in but that wont happen as its pissing it dwn 2mz..if u look at my posts flynny I said its happened to me a few times..last time It happened was about 8 years ago and I knew then wat it was its fecking obviousSo say it happens to you tomorrow are you gonna blame the weather?
for f**k sake there is a window in the room, it's an unusual scenario I agree, but let's not pick on basics and ignore the obvious.Ye if I was skimming sumat with a warm breeze blowing in but that wont happen as its pissing it dwn 2mz..if u look at my posts flynny I said its happened to me a few times..last time It happened was about 8 years ago and I knew then wat it was its fecking obvious
Exactly lolNo experienced good spread rings there boss up flapping and getting his knickers in a twist wen there ceiling starts to peel on a hot summers day with the window open..clue is in the pic its rite above the window
Not getting a bite from me flynny 2 late for thatExactly lol
And he put 3 ceilings on at same timeF**: an expierenced plasterer can id that as soon as they walk in the room and look at it.
The guy simply lost control of the set.
Doubt it was material.
Finish is pish.
I always bite .. Big mac always keeps me goingNot getting a bite from me flynny 2 late for that
I,,,he should have been quicker and done 4 at the same time.And he put 3 ceilings on at same time
Luv it how people always blame the multi
I don't see how that's relevant unless your slow, on a reskim or a very good price. The pic with the window I would say the ceiling is no more than 12m . Pretty sure it was all board so three ceilings is only a small gauge if they are a similar size and I would get them out of the same mixAnd he put 3 ceilings on at same time
Must have been a hole in the bag...letting a breeze inWe had some multi from tp in Norwich on a re skim job second coat wouldn't stay on the first coat. First coat went fine put second on just after flattening then flattened off and just started peeling off when trying to trowel it. only way it would stay on was to run a brush over whole wall. We tried everything else. Tried changing our prep, tried going over different surfaces then decided we had tried enough different approaches to blame the plaster.
We also tried the gear on a different job onto plasterboard and it done exactly the same.
It wasn't a whack in like a game show kind of thing it was more a case of, I couldn't find the "what a load of b*ll***s" button and that was closest so I gently brushed my finger over the screen and touched itLol Flynnyman wacking disagree button now ..ohhh now who spitting dummy out?
That would spoil the fun it's only the internet world lolWhy don't you 2 give each other the friendly button.
Perfect for Flynny wackerView attachment 11492 A option like this would be handy....( even for a laugh)...bit noisy tho
