D
Deleted member 32554
Guest
Not the first time I've had this problem , end up wedging the power lead at an angle to get a charge , any tips
New one, @tightwad.Not the first time I've had this problem , end up wedging the power lead at an angle to get a charge , any tips
I'm not laying out another £50 lolNew one, @tightwad.
Where are you buying charging wires? They're only about a fiver.I'm not laying out another £50 lol
Got me granddaughter's first birthday to go to so I'm gonna leave it propped with a full kettle pressing on the connector
It’s just usually fluff out your pocket compressed in there, tooth pick or similar and scrape it clear give it a gentle tap on the worktop and you should be sorted.
Like that Stevie , eBay here I come
Lol you'll get to know how tight I can be , the phone was £50Where are you buying charging wires? They're only about a fiver.
The brush you get with a pair of clippers is good for that.It’s just usually fluff out your pocket compressed in there, tooth pick or similar and scrape it clear give it a gentle tap on the worktop and you should be sorted.
Not bad for a crusty old man in a Motherwell bed sit.Get your self something like this, absolutely amazing.
allcaca Charging Station Multi 5 Port with Wireless Charging Pad, Charging Dock Organizer Removable Baffles for iPhone, iPad, Samsung and other Devices, 5 USB Cable Included, White https://www.amazon.co.uk/dp/B07QMS635P/ref=cm_sw_r_cp_api_i_rWmgEbFNM75XQ
I f**k about one phone every three months and it's always s**t in the charging port that does it.
Sometimes stevio is a bit too honest for his own sake , it takes all sorts apparently , but that's got to be the extremities of the human sexual horizonKinky!
He was in tears when they did away with the headphone socket.Kinky!
Universal Qi Wireless Charging Receiver for All Micro-USB Android Mobile UK | eBay
· Low heat emission, new improved high efficiency Qi wireless receiver module chip. · Standard: Qi Standard Transmitter. · 2 USB Types for choice: Micro USB1 / Micro USB 2 (As picture shows). 1 x Wireless Charging Receiver.rover.ebay.com
But you have to put it down.I use a wireless charger... so much easier
I've got a charge port in my radio. Radio is Bluetooth so it's all good.
