Plaster fail
  • Thread starter Thread starter Deleted member 29624
  • Start date Start date
No Pete wasn't uni just normal multi...took the wall off today and done it with grit, to be honest the whole wall came off without to much of fight so don't know.....about the bottom meter was stuck on well
on the back of the plaster was there paint?
Nope no paint plaster didn't stick, pva'd whole room at the same time and no other walls blown so got no idea. Skim it again tomorrow and move on I suppose
For u guys that reckon sunlight cannot dry it out too quick then think again.
That uni failure i had that i blamed on sunlight,well.
1 month after i repaired it customer calls me,s**t i thought not again.
No he asked me to come back and do a window wall in next bedroom that is to front as well.
Looked at it,,,when i came to do it he said can you also fix that bit there i forgot to say to you.
It was a bit that was cracked ,well it was blown,and it came off identical to the room i done,,,,carbon copy,,,i have pictures.
This room was plastered 3 years ago using pva,multi not uni.
Not by me also.
So 2 rooms blow different plasterers,different system,different coloured paint in both rooms.
Only thing in common,,,,both are left hand side walls in a south facing bedrooms where sun tracked right down them.
Pictures will follow.
Plaster fail
Same as other bedroom plaster wont come off that's out of sun line.
No coincidence.
BG are paying me compensation as a good will gesture.
By the way multi fails as well as uni.
