Adam clifton
Hi all was going to skim a stairwall Friday but after close inspection it was blown & ended up taking it all back to brick , I’d say it’s possibly 1950s house , there is a garage attached to it so a good half isn’t exposed as it’s external wall , was going to use s/c as it’s an external rather than bonding . The gap from the string is quite tight in spaces possibly 9mm , the window cill is staying & as also the string so I am governed with what I can use on the walls .
