D
Deleted member 32554
Guest
Artex isn't solid thickness all over , so the thicker parts only cover a small area's so is less prone to crackingb*ll***s. By that logic why is the existing fine? How would a fex extra mm make any difference? Don’t say the extra weight as it’s distributed ovef the entire area.
Only overboard if ceiling is failing
Another point is your relying on someone else's work , it should be checked that its not
already a cover on old skim , more bonding issues , dirty boards , dry PVA etc
