Been reading this thread with some interest and i think some of you lads are looking back with rose tinted specs on.
So i`ve run the original post through an historic inflation calculator and it came out at .
Remember these were the contractors rates and not what blokes rekon to earn back in 83
Render (1:1:6)and set in Siraphite
Walls £6.17 m2
Walls to staircase areas £9.34 m2
Walls in Bonding and Carlite finish £6.59
Scrim joints and skim coat to plasterboard
Walls £4.11
Ceilings £4.50
Angle bead 70p linear
Stop bead 83p
2 coat PVA £2.72 M2
Now i know where i am in relation to those prices and i'd prefer to be in 2012. You lads can make your own minds up.
One of our problems is once you have the skill set to achieve an exceptable finish and producing a sensible meterage , you have no where else to go. You can't produce a better finish , the product itself doesn't allow for more to be done in the same time period, so you're stuct with what you are. There's no corporate ladder to climb , if we take the previous post of a teacher as an example . The young teacher starts off on a salary , shows an attitude and is willing to work , progresses through the structure head of year or head of department and so forth. More and more responsibility and salary increases accordingly. But we can't do that, we can only set ? squares a day. So you're stuffed , for reasons mentioned above. Alternitives , you find a premium product that you can charge a premium rate for , in my case lime work, or you take on bigger and bigger contracts and more and more spreads in order to service them. The problem with this is you still only get the same meterage rate and the bigger the company , the bigger its over heads . So the smaller the percentage profit. To the point where you've got to pay the spreads themselves less than you would like too. This is why i can go and overskim mrs jones kitchen ceiling for £10 per meter as the primary contractor , but the same ceiling for a local builder as a subby , would be 75% of that. But as an employee of a large company , you would be lucky to see 33% of it. It's just the way it is and if you don't like it , get out of the game.
