Rendering celcon blocks
luke105
Evening all,
I have asingle story building with celcon blocks that I need to render. I’m thinking my options are either making a brush on slurry of sbr, sand, cement, water, wait to dry then scratch coat as normal.
Or would galvanised steel mesh be a better option?
or am I well out and someone here has done a few of these and found something that works? Ratios would be great.
Thanks.
ps, the building has had an alteration after completion hence the odd block work to the left of the door. Not looking for comments on this. Thanks again.
  • Rendering celcon blocks
Evening all,
Thanks.
Ok no mention of the shoddy block work then. ............Wtf happened above the door :oops:
You need to slurry that and at least press Fibrous mesh mat into your scratch as you go. EML sucks imo
PS
I’ve never done it
the upvc cladding had to be cut out to make way for the door. It needs an end trim putting on around the cut out that’s all. The block work has been patched in as there was a window there. The block work doesn’t need to be the Mona Lisa when it’s being rendered. The steel straps will connect the old and new block work together hence why they are there.
Now that’s been explained any help on the actual rendering would be great.
Thanks.
If you want a system that works it’s 2 coats of micro gobetis parex primer and then 15mm of Parex monorex with mesh
will the door handle not break the kitchen window
The door has a metal bar at the top and bottom which prevents the door opening that far. Although the door handle Doesn’t reach that far Over the window sill to actually hit the glass.
Thanks.
What material is being used?
HI thanks for reply. I’ve only done sand and cement and Weber one coat before so I’m not confident in trying a costly product. Sorry I should have probably mentioned this.
The big issue and main reason for the post is the suction issues with celcon blocks...ie, blocks sucking the the water out of my mix. Preferably sand and cement or Weber one coat system and I’m just hoping someone has rendered over celcons before and has found a method that works well. Cheers
If your going down the s&c route your mixes need to be spot on over lightweight blocks,or the whole thing is pointless,if this job is for a paying customer I would walk away from it no point chancing it if you haven't rendered on lightweight block before
It’s my own so it’s not an issue. But the same time I don’t want to go through it all and it fall off wasting my time.
do you know the correct method and ratios?
I’ve rendered over celcon. I pva’d em, not water proof pva either!
Now that comment is gonna get people wanting to leave this forum I know - Or ask Danny to boot me off!
As sure as eggs is eggs it will crack unless you put mesh in
Ok so you think, pva the blocks....allow to fully dry (overnight whatever) then sand and cement scratch coat with mesh...then after that just top coat as normal?
Yeah I do
That mesh you get in a meter wide roll
But I’m aware sbr slurry is really the consider’d best method. Just think buildings need to breathe myself?
But first Try pm @Rigsby the rendering ninja he would advise best or @church
Yeah I do
Thanks.
I do like the slurry option to be honest but happy to go with someone who’s actually done it! Mesh as in not the steel mesh but the fibreglass mesh stuff?
Thanks.
Fibre yes, towel it in as you go in patches.
Steel starts going down the three coat work route cos of the over lap thickness
Get more replies to this thread before listening to me :frenetico:
so I’m hoping slurry, scratchcoat with mesh, then top coat normal. Just need the best ratios if anyone can assist
Well parex is similar to Webber pal and will work over these blocks
You can just lightly water the blocks , don’t soak it , apply sand/ cement at 5/1 with a water proof as a scratch . Then the top coat can be 5/1:1 sand cement/lime or even 6/1 .
a splatter coat slash scud coat before scratch isn’t a bad idea.
No fn pva .
Whatever happens rendering on aerated blockwork is a risk and disclaimer should be put in place,
Render layers should be progressively weaker so you're already fucket because the substrates weaker than the render, don't know why building control and architects still come up with the idea knowing that it's got to be rendered,
I would use a pre bagged high polymer fibre reinforced adhesive render with mesh laid in and stipple coated or keyed such as
Rendaid
Key coat primer
Sp22
No fn pva .
Thanks for your reply. Have you done this before? This was the method I was hoping for.
Can i ask why you chose to build it using celcon blocks in the first place?
