Cheers Tom,Terylene over it quickest cheapest way to make it look respectable
Would this give a smooth finish,
Would it have to be re-beaded ?
No it would be a textured finish not too rough but would be your cheapest option no need to re beadCheers Tom,
Brill thanksNo it would be a textured finish not too rough but would be your cheapest option no need to re bead
Thanks Malc, im really thinking of knocking it off and starting again tbh. Just painful that supposed tradesman leave it this way and think its an acceptable finish.
£600 materials and labour. Done in a day 3 ladsHow much you pay? f**k every1 else's comments,thats the killer question? If been asked already,apologies
Thanks Malc,you may be able to save knocking off. mix up a bucket of soft sand, cement with a dash of SBR. add water till you have a liquid mix. wear a glove, load a sponge, go completely over the wall in tight circles. leave to dry. i have corrected large areas of render using this method.
Thanks Malc,
Whats the ratio of each part please ?
Brill thanks for the helpi would use a strong mix as you are only adding texture. equal parts sand and cement.
You've done each other up like a kipper.£600 materials and labour. Done in a day 3 lads
What would i be looking at as an estimate. 35m2 sand and cement + beads.You've done each other up like a kipper.
Best wishes though xxx
Where are youWhat would i be looking at as an estimate. 35m2 sand and cement + beads.
I had a quote for parex and it was over £4k which i thought was extortionate but maybe this is the goin rate.
He's probably in the living room or the kitchenWhere are you
35m2 is nothing the fact that it took 3 guys a whole day and still left you with a substandard job and they walked away with £600 less materials and expenses tells it's own story.What would i be looking at as an estimate. 35m2 sand and cement + beads.
At home, you?Where are you
Could be taking a s**t, not necessarily in the bathroom, so you could be right.He's probably in the living room or the kitchen
Very true, thats why Im asking is £600 cheap so is it expected to be a cowboy job. Is £600 too much and should it have been perfect ?35m2 is nothing the fact that it took 3 guys a whole day and still left you with a substandard job and they walked away with £600 less materials and expenses tells it's own story.
Stockton on tees mateWhere are you
Not discussing rates but way too cheap!Very true, thats why Im asking is £600 cheap so is it expected to be a cowboy job. Is £600 too much and should it have been perfect ?
For the area and material used what would be a reasonable estimate in your opinion
Thanks Tom, im glad i didnt pay any more to the lad. Like i say i know nothing about rendering u just expect and assume the guys are going to do a good job. Shame really that it happens but hey hoNot discussing rates but way too cheap!
Can't say really, prices vary so much across the UK.Very true, thats why Im asking is £600 cheap so is it expected to be a cowboy job. Is £600 too much and should it have been perfect ?
Thanks Paul,Can't say really, prices vary so much across the UK.
By the time you rectify their mistakes you'll probably be at the price of a plasterer who knows what there doing and has pride in there work and charges accordingly.Thanks Tom, im glad i didnt pay any more to the lad. Like i say i know nothing about rendering u just expect and assume the guys are going to do a good job. Shame really that it happens but hey ho
Get one of regulars of here .....not meThanks Paul,
Im on the hunt for a more reputable lad so ill do some homework and let you know how i get on.
I appreciate everyones advice and comments
Good luck with your job.Thanks Paul,
Then they’d fail on every job and this hasn’t happened@malc, @johniosaif /others- You know about these , I don't - basically they are all forms of thin washes or skims onto the render - from your experience what about water penetration and frost damage blowing it off ?
Being an outside wall, exposed and down to the ground, no overhang/eaves etc I'd have thought a risk in a year or two?
I assume the SBR in the mix should sort it
Not done it myself , assume wall is left to cure and dry , would you dampen y surface before applying
Second pic, one word - stoned!!! Or pissed
