View attachment 78140spoke to soon
This wall took all day to go off so surely can't be drying too quick..
I'm stumped
It's straightforward mate!
Your mix ratios!
100%
Thank me later.
I'm stumped
1st coat
8 Plastering sand
Half bag cement
500ml waterproofer
Top coat
9 plastering sand
Half bag cement
2 shovels hydrated lime
Where am I going wrong?
Makes a lot of sense. Thank you, really appreciate it
Ŵe used to add fbres in the scratch coat many moons ago before good old ocr came along . That's a proper old school trick that is that only a few of us old dinasors use .Stay with 1st coat (I'd add fibres myself though)
2nd - go 8 to ¼ to 1 (and fibres again (small ones))
These we used to get when the dreaded bell mixer raised its ugly head View attachment 78145
I reckon the original Fibremesh (?) brand used to be 40mm long. Finer than a human hair and never had any problems with them. In fact they were way better than the modern clumpy crap that's available now.That's them, although we changed to 6mm
Found 20's could sometimes pop up "out" on warm days rubbing up.
I carry 2mm , 6mm and 8mm fibres now.
Don't even see them.
Work well though, knit it tight.
I reckon the original pubes (?) brand used to be 40mm long. Finer than most hair and never had any problems with them. In fact they were way better than the modern clumpy crap that i have now.
Fibre mesh that's the stuff been a long time since we used them tbhI reckon the original Fibremesh (?) brand used to be 40mm long. Finer than a human hair and never had any problems with them. In fact they were way better than the modern clumpy crap that's available now.
I used to buy it from a local ready mixed concrete company up to about 2004. Definitely the best one that has ever been available. A quick stir into your mixing water and the fibres completely separated, never a single clump of them. I used them for both screeding and rendering.Fibre mesh that's the stuff been a long time since we used them tbh
Showing are age now . Ha haI used to buy it from a local ready mixed concrete company up to about 2004. Definitely the best one that has ever been available. A quick stir into your mixing water and the fibres completely separated, never a single clump of them. I used them for both screeding and rendering.
Possibly, but I thought the original ones were polymer fibres not fibreglass?I think that's the difference between fibreglass and polypropylene fibres.
We used to get proper fibreglass that would separate equally/evenly through the water first, you stick polypropylene ones in there and it looks like frogspawn
Probably cheap Chinese shite flooding the place again?
Yes mate I did and do, mainly because that's what the manufacturers called them.I think so, we still called them fibreglass though. (Still do)
Did you call them polymer fibres?
Be honest now???
Not the good ones, haven't been able to find them in years.You still using/getting them?
Go to bedconcrete is so much more solid than screed and render
that cracks and never has fibres
it's set it steel
what makes sand and cement and fibres stronger
out of curiosity
The fibres I first bought were made for the concrete industry you thick c**t. They work in two ways. Millions of fibres criss crossing in the mix give added strength (hence why fibres are spec'ed for screening in place of steel mesh for most applications) and if cracks do form they follow the paths of the individual fibres, meaning that the cracks are ultra fine and usually invisible to the naked eye.concrete is so much more solid than screed and render
it's set it steel
out of curiosity
Same applies to the hairs in lime . Ha ha there's some M T HEADS on this here forum alrightThe fibres I first bought were made for the concrete industry you thick c**t. They work in two ways. Millions of fibres criss crossing in the mix give added strength (hence why fibres are spec'ed for screening in place of steel mesh for most applications) and if cracks do form they follow the paths of the individual fibres, meaning that the cracks are ultra fine and usually invisible to the naked eye.
Go to bed!I think the large aggregate in concrete acts like type 1 MOT subbase and all the stones play off each other giving great resistance
Same reason screed still cracks with steel mesh embedded mate. Outside forces. Rendering will be for a multitude of different reasons. All you can do is take as many precautions as possible.so why does the render and screed still crack
Yes till the top coat goes on that's why it's sprayed down as much as possible . No material contained water is guaranteed not to crackbut lime still cracks aswell
You'll know as well as I do that on site the same plot types will have cracks in the same place, that's got to be down to design, hasn't it?
You have to press the 3 dots
My house is to calm mate, his little head would implode.fuuck off andy
your the reason why fish fingers have gone up to
£7.75 a box
gonna send Fin to you for a while
il have him back when he's fit to earn
@Danny my little faces things have ceased to exist
