Rigsby
TPF Special Forces
I'd not spray with out a pump tbh
I always sprayed with the pump but then I got into thinking cut down the risk of breakdowns to a minimum. Had two expensive breakdowns due to the lab forgetting to turn the water on.
On houses with obvious good water pressure and everyone out I started spraying off the mains. One or two less reasons to cause a breakdown.
