Weberwizard
Kin hell thats quick how many l/m is that is that the new soft r&s some game changer thatLink Removed
Here's a ritmo l spaying with a new r/s if that helps
Link Removed
No Rob ive not really used the ritmo that much in the last couple of monthsDo you have a soft r & s mike?
What's a soft R &S??Do you have a soft r & s mike?
i think its better for KrendWhat's a soft R &S??
I Think your right RobA new one that's out
Only been tested I think though
I have the soft r@s. I find it quick don't know if it is supposed to be. But it is.
I only did about 15 bags but I remember thinking f**k me this is fast.They certainly look quick
I hope it's all positive feedback so they make them for everyone. I was spraying a render and was having problems with it even with the clamp r@s. I tried the soft r@s and had no problem.I think there was 20 prototypes made for testing
I had to get a clampable for using K rendi think its better for Krend
Hopefully it will be a few years before I use it again lolLuckily I've not used Krend for years lol
Yes they were a few sent out for test. We are still waiting for data back on them but none of them have worn out yet lol. Some guys are close to 30 pallets render. Chances are they will be put into production as the d 63 soft has been very popular.
Im not sure if they are actually faster but a new faster rotor and stator has allready been developed for the ritmo. I expect to hear something soon
Seemed to set in the pipe canny quick for my likingThe krend k mix is good to spry
Only put the hose down for abit to help rule off and it blocked up. Pressure was higher than 6 like knocking on 15 if I remember right. You defo spray wetter than me marraSpray wet arti.
I've never had it set in the pipe
6 bar back pressure mind!!
ROB is correct. You have to spray the kmix very wet and it will work spot on. By the time you got 10 m2 sprayed on it will tighten up enough to ruleOnly put the hose down for abit to help rule off and it blocked up. Pressure was higher than 6 like knocking on 15 if I remember right. You defo spray wetter than me marra
From what i have seen the rotor programme for the ritmos is developing all thw time. There was 1 rotor stator for a while now there are more already available and more in the pipeline for u ritmo people.
Cheers for the heads up on the Kmix @Orangemachineman @PFTwales
Now I feel bad lol sorry
