Ritmo m or eze k4
Vincey
Tbh I’m not sure , if mines an l or an m but I don’t use separate compresser
theclemo
That’s interesting tbh. I would guess it will be not as smooth as it should be , or I am completely wrong?
Go's on no problem. Can use an order compressor to spray a mist. But it's even more overspray. And u have to travel it anyway.
#51
Does anyone successfully spray finish on on the regular?? Seems most on here have given it a go but sacked it off after w while
essexandy
I was thinking more of silicon bucket finish, like the EWI
I'm sure I saw a video of either Ian or Stuart spraying that without any extra compressor. I remember that they lined the hopper with a bin bag to save clean-up time.
vfr12
I have done it with separate compressor, stronger that can keep up with the job -LK402, if I remember right. For plaster and render you use the onboard one, but for bucket finish you need extra 1k+
#56
So decided on the ritmo m, as wanted skim setup so needed to keep costs down, it claims to pump 20m, is this true, what kind of heights would it begin to struggle, id never be higher than 8 m?? With mono, cpi
