deanlangan123
Do you need a separate compressor to use 'spray finish' with a ritmo m with skim setup
Yes,and control cableDo you need a separate compressor to use 'spray finish' with a ritmo m with skim setup
NoDo you need a separate compressor to use 'spray finish' with a ritmo m with skim setup
Our Ritmo will spray the finish using just the onboard compressor.
More air just atomises the material.That’s interesting tbh. I would guess it will be not as smooth as it should be , or I am completely wrong?
Couldn't tell you as I've never sprayed so much as a bagful using our Ritmo.That’s interesting tbh. I would guess it will be not as smooth as it should be , or I am completely wrong?
Again in english plsGo's on no problem. Can use an order compressor to spray a mist. But it's even more overspray. And u have to travel it anyway.
But less will let you with tyrolian like finish?More air just atomises the material.
Fatarm googles atomises...More air just atomises the material.
That's exactly how the Thistle Spray Finish is supposed to go on and then spatted over.But less will let you with tyrolian like finish?
I was thinking more of silicon bucket finish, like the EWIThat's exactly how the Thistle Spray Finish is supposed to go on and then spatted over.
I'm sure I saw a video of either Ian or Stuart spraying that without any extra compressor. I remember that they lined the hopper with a bin bag to save clean-up time.I was thinking more of silicon bucket finish, like the EWI
I think @Vincey does it on a regular with multie but maybe I just dreamt itDoes anyone successfully spray finish on on the regular?? Seems most on here have given it a go but sacked it off after w while
I have done it with separate compressor, stronger that can keep up with the job -LK402, if I remember right. For plaster and render you use the onboard one, but for bucket finish you need extra 1k+I'm sure I saw a video of either Ian or Stuart spraying that without any extra compressor. I remember that they lined the hopper with a bin bag to save clean-up time.
