Second opinions
essexandy if you took more care on the bg website you'd see the caviot in the selector guide saying "not on smooth or low suction blocks" in that case, and this is where I have generally come across 2 coat work on dense concrete blocks (paint grade), so the spec I use is Bondit and bonding coat.
When are low suction concrete blocks used in houses? There 99 percent medium density or aircrete
if you paid more attention you know it all bellend you would have seen that it actually says not on smooth low suction blocks. there is no or in the sentence. hardwall is fine on standard concrete blocks.
Thank you Nick.
We really do need more tossers like this on the forum.
If you're for real then you really are a thick gormless ****. Apart from that you're fine.
Cause bonding is designed for low suction backgrounds i.e concrete blocks, hardwall is designed for high suction backgrounds like lightweight blocks etc, if you have used hardwall on concrete blocks before and it has worked then lucky you and prehaps 8 out 10 jobs you may get away with it, but when it falls off and you try to complain think you may find bg throwing the whitebook back at you. I suggest some of you do some homework and try reading bg/knauf/tarmac lit and educate yourselves in the materials you use!! people who don't know their stuff give us knowledgeable spreads a bad name
:RpS_thumbsup:
:RpS_lol: How many metres of concrete blocks would you say you've applied bond it followed by bonding to Smudge?
Talk about making life hard for yourself. :RpS_blink:
Not when its been spec'ed by the architect, the last job i did was a refurb of some sports centre and corridors were unpainted smooth, dense concrete blocks, the architect didn't want to dryline them beacue he wanted good impact resistence due to high traffic, so wanted a 2 coat spec, was about 400m2 altogther (for dans info)., and if people are having to double check my mis quotes, jesus some of you need to get a life yourselves, thought the point of a forum was to air your views. Essexandy was quick to try to correct me when i said you should be using bonding on dense block, but as i have previously mention IN MY EXPERIENCE in the work I have done when I have come across this type of background, had I used Hardwall I would have had some very very expensive callbacks!!! bunch of self righteous *****
ha you really are a wally .
were not self rightous, were just right. just admit your wrong and all will be forgiven. :-)
might be expensive and time consuming but I price the job right, and I make plenty of cash, and the bonus of it is the architect recommends my company to all his clients and other architect practicies so yeah as a company we are pretty busy thanks nicklearse/Dannymac, if your short of work give me a bell could always use a couple of good labs :RpS_thumbup::rolleyes)
Awwww thanks, that's really thoughtful. Busy for the next few months but maybe after Christmas. I'll bring my inch brush for the bond it.
I would want to fit right in and do everything the hard way. :RpS_lol:
would we be able to suck your balls too and tell you what a hero you are? slowly, of course....
Feck knows I thought all blocks were concrete just different densitys?
Yeah you're right of course mate but everyone I speak to refers to the Celcon type blocks as either just Celcons or thermos and any really dense heavy blocks as concrete.
The place we're on at the moment the load bearing walls are similar to those shown by Bubs but you can actually see small stones in the block mixture. And there's not a jot of suction off them.
in my experiance bonding will stick to class.remember a job in did in a school refurb for a plastering contractor,we had feckin meters of old tiled walls to sort(thick things,think they were green).
builder gotus to pva the tiles,float with bonding then set as normal.
my cousin works at that school and the plasters still on 15yrs later!
