Speedskim ST SF pole holder fix
lurpak
Artex Boy
Due to the design fault of the pole attachment they become loose even when tightened.
Good excuse to clean the filthy bitch too.
@Olican has drilled his in for a more solid fix which is what i’ll Probably do next but for a quick fix you can slide some thin plastic underneath then tighten the attachment
I’ve got the sf blade to try. And no @essexandy it isn’t freebie.
Thoughts on sf blade ?
On a serious note whats the sf blade like? Used to have spat and thought that was shite so always been put off
Thoughts on sf blade ?View attachment 27855View attachment 27855View attachment 27856View attachment 27857View attachment 27858View attachment 27858View attachment 27859
I got the sf but I’m still in mixed thoughts about it but I’m stuck in my old ways with ss trowel.
Same tbh I rate speedy st but only ever use it on big ceIlings now everything else is stainless mt sometimes last one with plastic to finish it quicker
Aren't they supplied with packers now? Lol
I may get the other blade just to make life easier. And some thing new to play with for the time to pass. I haven’t done much skimming lately to try it out mostly external render or dabbing tacking meh.
Same here not really given myself time to get use to it keep going back for my trowel
Can't use it on walls feels weird. Good for flatten on big ceilings. The SF blade was an impulse buy propably shite
Probably because you're a skim monkey. Anyone with decent featheredge skills would find them easy to use on walls, whether they like them or not.
