Good luck I hope it works for you, I've used mine for 2 jobs it's been sat in the garage and has warped to ****, if it took time of the set I'd just about understand it seems like most of you are flattening with it then troweling up with a trowel which I'm struggling to get my head around if you want to save time one coat it, if you're using a machine I'd understand because you have to keep up with the bloke spraying but then you finish it with a trowel, it seems like it was brought out to fix a problem which was never there unless you believe the particle vibration stuff, a metal blade will be brought out it'll compete with the eze spat and the plastic speed skim will slowly disappear .........
