KevRM
nothing wrong with using the sponge float, if you know how, a good plasterer should be able to adapt to any method to do the job, I've seen some rough arse spreads using traditional "correct" methods leave walls that I personally would be ashamed to leave that way, my advice is try it if it works the fair enough if it doesn't then stick with what you know
