Elite exteriors
Anyone else horrified at how the sun at the right angle makes perfectly good rendering look bad for 5 minutes usually whilst you are talking to the customer
2nd rule of plastering . Always see where sun rises n setsAnyone else horrified at how the sun at the right angle makes perfectly good rendering look bad for 5 minutes usually whilst you are talking to the customer
I usually walk round the corner where it still looks good and try forget about it I've tried everything and come to the conclusion you cannot beat the sun it shows everything2nd rule of plastering . Always see where sun rises n sets
You don’t2nd rule of plastering . Always see where sun rises n sets
I wish it looks like two 6 year old's did it but only for 5 minutes the rest of the time it looks flat as f**k![]()
I’m guessing it looks something like this
Rule it like your going to skim it, let it sit then check with a rule again to avoid slumps, rule your scratch, look across it from shallowest angle you can , check twice , check thriceAnyone else horrified at how the sun at the right angle makes perfectly good rendering look bad for 5 minutes usually whilst you are talking to the customer
Yeah you can put a straight edge on it it's as flat as you could possibly get it it's not my first rodeo buddy it doesn't matter what you do you can't beat the sunRule it like your going to skim it, let it sit then check with a rule again to avoid slumps, rule your scratch, look across it from shallowest angle you can , check twice , check thrice
Yeah it's not my first rodeo buddy
No offense there buddy,. Beg to differ thoughYeah you can put a straight edge on it it's as flat as you could possibly get it it's not my first rodeo buddy it doesn't matter what you do you can't beat the sun
Haha even if you could it still wouldn't matterAs @Rigsby said; always work to a compass if light is catching it low
You don’t
#Midnight skimmer
If you shine a torch across a flat glossed door you can see the brush strokes.Rule it like your going to skim it, let it sit then check with a rule again to avoid slumps, rule your scratch, look across it from shallowest angle you can , check twice , check thrice
Yes not for long tho and a same day scrape with a i bar will reduce the shadows a fair bit2nd rule of plastering . Always see where sun rises n sets
Thanks never knew the 2 hour rule handy to know that one to back yourself up in those situations, most render looks bad with sun at the side no matter how good u are ! Apart from k render that's been same day scrape with i bar I can get that pretty good with sun on it,all down to the ruling off I'd say guys but were all differentThat is why british standard gives you a 2 hour window for the sun to move. If it still looks poor then you have a problem.
Rule it perfectly I section it perfectly make love to it it doesn't matter a same day scrape with krend or any other product doesn't matter on a certain angle in the sun it looks different anyone saying differently are in denial or lyingThanks never knew the 2 hour rule handy to know that one to back yourself up in those situations, most render looks bad with sun at the side no matter how good u are ! Apart from k render that's been same day scrape with i bar I can get that pretty good with sun on it,all down to the ruling off I'd say guys but were all different
Keep working at it, you'll get thereRule it perfectly I section it perfectly make love to it it doesn't matter a same day scrape with krend or any other product doesn't matter on a certain angle in the sun it looks different anyone saying differently are in denial or lying
Haha been trying long enough I might be better off stacking shelves in tescosKeep working at it, you'll get there![]()
Ahhhh grasshopper (said in a Chinese accent2nd rule of plastering . Always see where sun rises n sets
NoAnyone else horrified at how the sun at the right angle makes perfectly good rendering look bad for 5 minutes usually whilst you are talking to the customer
A plastrer enemy will always be the sun!Anyone else horrified at how the sun at the right angle makes perfectly good rendering look bad for 5 minutes usually whilst you are talking to the customer
Yes And electricians they are also the enemy the two hardest battles since the trade beganA plastrer enemy will always be the sun!
Yes lol electrician second joinars third the list is endless? HaYes And electricians they are also the enemy the two hardest battles since the trade began
