John j
Mono Don
They dont care mate, not even worth typing your greivence!
spent an hour on phone this week to bg first then formula the casting plaster makers its 80 bags or f/all internet sales want £30 per bag delivery plus £14 a bag so think I will call it a day cant be f**k*d anymore just turned 2 jobs down this week just going to do a few patching jobs kitchens etc THANKS ST GOBAINThat's bad patter mate, that shouldn't be right.
Seriously mate I thought after using uni I want to try them all to find which one I thought was the best , tbf I think all the skim plaster they do have different advantages, but the top two I liked to trowel up on plasterboard were pure and thistle sprayIve got an offe @bg
Tbf i honestly wouldnt have even heard of pure if not for @Vincey!
Though im sure hes on the payroll!
I use to just use my tyzack ss start to finish no problems. Now I only coat with it and use my old mt carbon to trowel up. The carbon is much lighter though, probably puts less stress on the surface. You know what I feel like I shouldn't have to post this shite.I still think they're adjusting the formula to better suit plastic trowels to "stay with the times"
Cause the gear hates a worn in ss
Unless they've changed the Spray Finish since release I can't understand how you'd think that is a decent bit of gear to use? Even BG advised the need for a plasi trowel to stop it tearing in the latter stages of trowelling up.Seriously mate I thought after using uni I want to try them all to find which one I thought was the best , tbf I think all the skim plaster they do have different advantages, but the top two I liked to trowel up on plasterboard were pure and thistle spray
But out of the two I’d go pure if I had to choice just one
What do some of the older guys who work at BG say about this issue .? Surly there are some of there demo team old enough to remember what finish was like years ago and see all the points being made by many of the experienced and long serving spreads on here.
How long you been spreading Lurpack?
I think they say "I'm getting very close to getting my full pension and I buggered if I'm going to rock the boat, f**k the spreads".What do some of the older guys who work at BG say about this issue .? Surly there are some of there demo team old enough to remember what finish was like years ago and see all the points being made by many of the experienced and long serving spreads on here.
I think you maybe right.I think they say "I'm getting very close to getting my full pension and I buggered if I'm going to rock the boat, f**k the spreads".
Can tell6 months mate
And sometimes you think wronglyI think they say "I'm getting very close to getting my full pension and I buggered if I'm going to rock the boat, f**k the spreads".
Welp got blanked on that one.
Not skimmed for a while but skimmed today, gear was rank really streaky and greasy, to much elbow needed cross ways to make it right
Aye...no water it tears, water and it streaks, only option is to leave but not ready to be left...just have to battle onHorrible enit. You can see the streaks straight away
I had that today , still tearing on last trowel when it was hardLeft set yesterday was completely turned went to cross is and pulled fat up n teared . Just disgusting shite
@malc im guessing you have always used MT start to finish, so why the super flex at the end? Is it the change you’ve seen in plaster over the years or just to make final pass easier?
Exactly with board other day I had a right s**t background it was masonary painted wtf so day b4 I used some thistle bond it first coat fantastic let it pull in 2nds on pulled in fast same scenario n like u left it in the end light trowel with Nela flex job done but what a f**k aboutAye...no water it tears, water and it streaks, only option is to leave but not ready to be left...just have to battle on
Thank you @malc, so few left to remember the good gear. How easy was it to use the coarser gear?i have only used Marshalltown trowel since the late 70s when i had to go to London to purchase my first Marshalltown.
i purchased the retina flex, it gave a good finish with not so much effort.
Multi finish is very fine compared to Sirapite which was a more open corse finish, more like the required eggshell finish.
It's not that you can't finish it, it's just really hard work and occasionally when bags are good it's effortless...that makes it more annoying that's it's right sometimes ....like bully....here's what you could have wonWhat seems to be clear, is the ones having issues are having the exact same issues. @Lodan described it well
See even a non spread has mailed the issues. Well done you bady builder (unqualified).It's not that you can't finish it, it's just really hard work and occasionally when bags are good it's effortless...that makes it more annoying that's it's right sometimes ....like bully....here's what you could have won
What a swamp donkeyNagative piss taker, go back back to spreading wondertex if you can’t work with finish, either way from what it sounds like your work needs sanding
Good job I'm Not easily offended ...I'd post some pics of my current loft conversion but know there'd be a load of internet warriors getting off on it finding a bead a mil out and getting a little self satisfied erection
I wish someone made told me earlier..just made.a feature wall and the top one 770m and the bottom one was 775m...very ashamedWell, don't put your beads a mil out and you have nothing to fear, do you?
