vfr12
MOTORC*NT
what is the recommended water ratio on the back of the bag for 1 bag mutifinish?Nope never have problems with it
what is the recommended water ratio on the back of the bag to 1 bag mutifinish?
I dont use their recommendationswhat is the recommended water ratio on the back of the bag for 1 bag mutifinish?
You definitely wouldn't want to try and use the shite mixed to their recommendations.11.5 ay it?
Disagree all you like andy i dontNothing wrong with the gear
ok,how much water do you use per bag then?I dont use their recommendations
A full yellow builders bucket per bagok,how much water do you use per bag then?
so,i am using the same buckets ,which means you are using around 15L per bag. I use 14-14.5L per bag .Taking on board what you say there is nothing wrong with the gear id like to ask you this question-why the gear needs 25-30% more water from what is stated on the bag?A full yellow builders bucket per bag
Just how i have always done it no big dealso,i am using the same buckets ,which means you are using around 15L per bag. I use 14-14.5L per bag .Taking on board what you say there is nothing wrong with the gear id like to ask you this question-why the gear needs 25-30% more water from what is stated on the bag?
Well there appear to be more spreads that agree with my opinion than yours Gary.Disagree all you like andy i dont
I only use board and my opinions are from my personal experienceWell there appear to be more spreads that agree with my opinion than yours Gary.
I have said that the pallet of Board Finish we had recently was considerably better than the Multifinish I've been using for the last god knows how many years.
Can't say fairer than mate.I only use board and my opinions are from my personal experience
i agree with you here , but when you loose £££££ youll start thinking differently.In generally we make it work,but that doesnt mean there is nothing wrong with the plaster by any means.The difference between the recommended and actually used amount of water shows you clearly how far is the plaster at the moment from the original and to say there is nothing wrong with it, thats a bit naive. Thats about 4 generations of recycled plaster. Next time you on site mix the bag with the recommend water ratio and tell me what do you think.Just how i have always done it no big deal
not much difference betweenI only use board and my opinions are from my personal experience
Would never do that i will stick to my method has worked for 35 yearsi agree with you here , but when you loose £££££ youll start thinking differently.In generally we make it work,but that doesnt mean there is nothing wrong with the plaster by any means.The difference between the recommended and actually used amount of water shows you clearly how far is the plaster at the moment from the original and to say there is nothing wrong with it, thats a bit naive. Thats about 4 generations of recycled plaster. Next time you on site mix the bag with the recommend water ratio and tell me what do you think.
Ive never lost money over iti agree with you here , but when you loose £££££ youll start thinking differently.In generally we make it work,but that doesnt mean there is nothing wrong with the plaster by any means.The difference between the recommended and actually used amount of water shows you clearly how far is the plaster at the moment from the original and to say there is nothing wrong with it, thats a bit naive. Thats about 4 generations of recycled plaster. Next time you on site mix the bag with the recommend water ratio and tell me what do you think.
Lot of differencenot much difference between
If its greasy get the windows open humidity does thatI’m more in the same boat as @Gibbo to be honest. I once was on a job where the gear felt a bit greasy but apart from that one time not had a problem. Been plastering about eight years so maybe just not long enough to know a time when it was better and therefore can’t make a comparison. Maybe I’m just lucky. I’ve never read the back of a bag of finish, if I had to do that I probably shouldn’t be charging for work lol
That makes sense I was balancing on planks over a stairwell in summer!If its greasy get the windows open humidity does that
sure you didnt . you are not motorcunt with a starIve never lost money over it
You lost me on that commentsure you didnt . you are not motorcunt with a star
Open the front door and a window up stairsThat makes sense I was balancing on planks over a stairwell in summer!![]()
I ment you did betterYou lost me on that comment
I’m on gibbo’s side
Sounds like he knows his gear
Spot on. No time to mess about now or take phone calls when you're wacking it on. Used to hang around for ages in the bucket bit you can feel it firming up each time you fill your hawk upGears 100% changed. Like clay now. Firms up fast in bucket too even new bucket
Use a hand board instead then,,,,,,Spot on. No time to mess about now or take phone calls when you're wacking it on. Used to hang around for ages in the bucket bit you can feel it firming up each time you fill your hawk up
