They are a bit hit and miss mate thats why i went back to mt
What problems are you having mate ??Never had so many problems ,we have tried leaving it going on it early etc , might use it to put on with it as it’s shite I think, prefer super flex all day long
A lot of lads are saying they are brilliant , but I’m either using wrong or there finish ain’t upto scratchThey are a bit hit and miss mate thats why i went back to mt
We have had them for a while , but we can notWhat problems are you having mate ??
Slight lines ??
Water streaks ??
Once u got 2nd coat on do u flatten with my 1st ? Or is it medi all the way 2-3 flats( trowels ) ?any help would be appreciatedWhat problems are you having mate ??
Slight lines ??
Water streaks ??
I find the trick with these trowels is use water at the start of hit and just keep blade wet towards the end.We have had them for a while , but we can not
Seem to get our walls looking good at all, when they dry it looks like we have chucked loads of water at the wall and flattened , but we used none ,
Ok will give that a try , thanks anywayI find the trick with these trowels is use water at the start of hit and just keep blade wet towards the end.
Keep it flatter than your Mt without any pressure.
Up it twice across it twice.I find the trick with these trowels is use water at the start of hit and just keep blade wet towards the end.
Might give it another goUp it twice across it twice.
Might take an extra swipe now it's a bit colder but I'm using 18" ....it's like a small spat.
Cheers buddy , so soon as flat with mt , don’t leave it and straight on with the medi 2 wets and then just keep trowel clean ? That about rightUp it twice across it twice.
Or is that a wind up 5 trowels ?Cheers buddy , so soon as flat with mt , don’t leave it and straight on with the medi 2 wets and then just keep trowel clean ? That about right
Yeh too much pressure n that’s when the frigging waves start n oh shootI find the trick with these trowels is use water at the start of hit and just keep blade wet towards the end.
So once u have 2nd coat on u 1st flat mt then medi 2 wet trowels then a crosstrowel ? Sorry to ask but we been having problems with themYeh too much pressure n that’s when the frigging waves start n oh shoot
I ain’t use mine fir while just use the nelaflex at end
I'm not sure the size of your hits mate or what size trowels your using.Or is that a wind up 5 trowels ?
Thanks for your help will give it a go TomozI'm not sure the size of your hits mate or what size trowels your using.
18" without pressure will whip around 50/60m fairly quick.
I've only started giving it a quick extra 1 since it's gone colder to keep an eye on everything.
You will find you can run around the tops without crates or benches towards end of hits with 18"![]()
We just put on around a bag an half give it a flatten then mix up to 2nd coat , that’s for one man , how much u mixing up for yourself ?Thanks for your help will give it a go Tomoz
That buckets average@algeeman ’s winter bucket being dropped off to site
Its your lucky day . I know one oing for a good priceThanks I may invest in a mediflex and give it ago.
Just swapped to wood as cork fell to bits . Didnt like it at first as it feels like a 50p piece compaired to a mt. Then i realised reason but cant explain lolTBH I'm loving the cork handles....suits me very well sir.
HAha bit late mate been there done that couldn’t get the hang of it.Its your lucky day . I know one oing for a good price
Ha noticed date on post after postingHAha bit late mate been there done that couldn’t get the hang of it.![]()
Good thing I am sooooooo completely on my game!!This was a good thread to bump As it shows @Gibbo really liked the mediflex and highly rated it but after time he’s gone back to mt. this is exactly what happened with me as mentioned in previous posts.
Can’t fault them trowels but they can create more problems if you’re not completely on your game .
Get some cbd oil worked wonders for my elbow and shoulder simply cbd liquid gold oneI do t think I could physically be without my nela now. My elbow is playing up again. So much so that.... and I’m going to sound like a nob..... I’m flattening with mt, then quick flash over (no water and when I’ve left it a bit) with nelamax and then standard nela. Trying to take all pressure off my elbow. Should really start doing everything but laying on with my left hand... in fact that’s exactly what I’m going to do starting tomorrow!
Thanks I’ll check that outGet some cbd oil worked wonders for my elbow and shoulder simply cbd liquid gold one
