Stevieo
Royal Spin Doctor
FFS... What do you think is holding it up?There are no uprights with this stuff. It's one big slab of compacted hay. It's bloody solid stuff
They just nail it to the joists and screw it to the floor and adjoining walls. I've got it in my house, I've ripped out whole walls of the stuff. Believe me I know lolFFS... What do you think is holding it up?
So it's just held up by brackets?They just nail it to the joists and screw it to the floor and adjoining walls. I've got it in my house, I've ripped out whole walls of the stuff. Believe me I know lol
They are very rigid , only seen them once , in this case they were two thick , joints broken and glued , possibly wired as well , the customer wanted sound boards on both sides as a reskim , pointed out to him he ought to soundproof loft but don't think he did lolSo it's just held up by brackets?
It's just held up by the other walls nailed to it and nailed to joists. No brackets that I ever sawSo it's just held up by brackets?
I dabbed with 100mm screws all over but in this case he's tiling so understand the need for good fixings with the extra weight
if my memory serves me correctly i think they used to be call stramit panels f**k**g heavy horrible things but warm as f**k
I'm disappointed in your capitulation I expected more from you mate lol , let's have a beer and think about it again , only seen it once myself so the solution is still up for grabs lol , here's a chance for your comeback , look what I'm drinking , Aldi lolRight then.
In 30 years on and off of working on new build houses and renovations I've never seen that.
I thank you for the education and offer a small apology to the OP.
Was going to tag you in malc for your extensive knowledge , but we was all having do much fun loli agree it is Stramit board, still available today. manufactured in Suffolk. invented in Sweden in the 1930s.
we always floated the boards usually sand and cement then skimmed.
it was also used on flat roof on industrial buildings which would receive a thick sand and cement screed.
i remember putting my foot through 1 roof where the board had been saturated.
That grapefruit beer from Aldi is awesome!I'm disappointed in your capitulation I expected more from you mate lol , let's have a beer and think about it again , only seen it once myself so the solution is still up for grabs lol , here's a chance for your comeback , look what I'm drinking , Aldi lol
Heard it all now lolThat grapefruit beer from Aldi is awesome!
Your mission should you choose to accept is head into Aldi and buy it and report back!Heard it all now lol
Grapefruit
Beer
Lol
Ok , proof is in the pudding@bof this is not a laughing matter! It’s very serious and tasty!
I hope you crush it before snortingLooks like tramp heaven at your house.
Can I come?
I'm down to tuborg and pepper
See the pictures from the loft... there are no uprights
If you can't plaster over paper, why do they cover plasterboard with paper?
The A Team is forming for actionView attachment 41372
Rip it down and build stud wall, or put stud wall in front. By the time you've thought about it, faffed and bodged it, I would have finished tiling the bathroom and would be licking the jam off my fingers.
Link RemovedLicking sausage fingers more like.
You f**k**g not right.
say again? lost me, need one of your drawings.Once you strip and expose the wall level out the joists by fixing some strips of thin ply to the sides of the joists at each end of the wall makings pair of vertical guides and every 4' or so in between
Score with Stanley knife and apply board adhesive , rule off with a straight edge let it harden , knock off any high spots
Then when you fix the cement boards put a bead of no nails on these areas to bed in perfectly
i know it as wood wool panels.that's the old compressed straw wall panels
ah there it is!How about forcing some metal straps down from the loft , then you have some weight bearing fixings for full moisture plasterboard that's dabbed
I've never known anyone seem to know what they're talking about as much as bof while at the same time talking complete and utter nonsense.say again? lost me, need one of your drawings.
Come back @Robbo123 , everyone's in favour of your procedure of sticking cement boards on the crappy old surface , admittedly with fixings.
Now how many fixings are you all going to put in to hold the adhesive , cement boards , tile adhesive and tiles
[QUOTE="Andyca,
It's getting tiled but I need a stronger surface to mount the cement board to.
I would just screw plasterboard to it with standard amount of fixings. Won't go anywhere. Even my door linings are just screwed straight into the stuffThis evening is looking like fun
Whole sheets of moisture plasterboard , more stable due to joints , cheaper , your door frames vibrate and joint is hidden by architrave , not the same as the weight of everything on a tiled wallI would just screw plasterboard to it with standard amount of fixings. Won't go anywhere. Even my door linings are just screwed straight into the stuff
Have you ever put a screw into this stuff? The fact you're questioning it means you haven't lol. It's like screwing into a piece of timberWhole sheets of moisture plasterboard , more stable due to joints , cheaper , your door frames vibrate and joint is hidden by architrave , not the same as the weight of everything on a tiled wall
