it looks to me that the ply is just used as packing. is it to line up the interior ?
Oops I disagree , now isn't that unusual,,,,,lolMay want to make sure the windows are wedged in tight. If so, I’d refoam that properly and you’ll have to make good with upvc trim and fascia over the steel.
A bit of careful trim and silicone work would cover that mess up and then patch in the render.
Only nit picking , did you mean " P****i" not "wedgie "
doubleNot sure where you’re going with this John!
ok thanks.
Pretty much confirmed what I thought.
I will take that wood out and foam it then just render it.
I don't like plastic trim
ok thanks.
Av a beer n relax lads
G** J.E.A.N.S A.R.E Y.O.U 12????
Only flat trim on the frames to help disguise the lack of skill using a tape measure when measuring up the windows.
Are you leaving the steel exposed ? I would shoot on timber to the web of the beam and the underside where they stuck in a bit of a floorboard , cover it in felt and mesh .Then render it .
Window is the wrong size. Should have added a clip on extender to make the frame bigger but they added ply as a bodge.. That's my thought
I was going to render them back they were already rendered...
This is on our offices and after a year from a builder who is meant to have done it all I have sacked him and need to do it myself.... yay
That ply in there looks fooked to me and I think it needs to come out but not even sure why it is there...View attachment 34217
I have an external, exposed beam over a sunroom that I want to box in to plaster/render. Apologies that it is partially hidden with the scaffolding
What did you do in the end to box in your beam before rendering??
I used blocks and cemented them in
I considered that, but I would wonder, how stable blocks are when cemented into an RSJ?
I am considering putting recycled plastic onto the web of the RSJ, instead of timber (which may rot in behind the plaster). I will screw cement board onto the plastic, to plaster onto.
I have thought about the timber, but I would be concerned about it rotting in time, therefore I want to use plastic instead if possible. In 10 years time if the timber gave way, there would be nothing to hold the board and the render may not self support itself leading to cracking.you could always wedge timber in and then screw and exterior render carrier board to it like aquapanel @Runswithscissors maybe abl to guide you on that
