Vincey
Thanks , I read on spray plaster bag it says if not spraying for 15 minutes just spray for 45 seconds to a minute then carry on as normal, would you say that's cool to do I.e I could just keep going then when all done stop and clean out when all gear is on ?Setup each day 10 mins, clean out 10 mins.
You will learn time saving tricks as u go. Clean using the r/s to push water through save f**k**g about with tap and u can clean the hopper as well.
If the flow of the plaster stops and starts like it has air in it then it because u are using the powercoat shaft. ( silver no up right arm) switch to the ritmo m render and it's sweet
Use the water pump. It can go direct on to the tap as well as a water butt.
If keep f**k**g it up just use it as a conveying machine. Even my dad can do that.
Water flow 100 speed 10
You can leave the build up in the chamber just spray out any wet stuff. This lets you not have to disassemble the mixing zone each hit. Just do it each day after final hit.
