Sounds easy! I like it already.
you have to spend time on a set of reveals, the same margin around the frame, square, and ruled both ways in the base coat.
Question is why are we so slow to adapt.
we have lots of plasterers that are willing to work cheap.
You are bang on the mark there.
Cos apparently it's s**t for reskims which is what domestics are.Nobody has commented on MP Finish. Is this not designed for spraying? 2+1 on a big room done in one go.
Ive used this in SwedenMp finish takes about the same time as multi etc to finish which is why its a waste of time. Check out Knauf Multi finish on youtube thats a 7 hr set
I've just bought a G4 and hoping to just render once I've built the work up
I think every now and then everybody got a client where they would love to do that without covering anything up, just spray everything and then leaveCan you imagine stomping in to little Mr and Mrs Jones' fully carpeted house with nice oak skirtings and facings with your ritmo to spray a 20 metre ceiling in their lounge?
Nope, neither can I.
This stuff?
In this demonstration it takes them 3 days to do 100 metres.
he was painting it on the 3rd day, that`s not bad really, i imagine it would be great for big areas but not with filling out the joints and things, it was almost drylined when they started, might as well just leave it like that, decorator will get over itLol..if only prices were that high so u cud actually take 3 days to do 100m2..thats y I dnt think machine spray for multi will ever kick off be it domestic or site work as you can bang it on quicker than wat the machine does..
I'm taking the machine to Stuart at UK plastering machines on Saturday to get it set up an serviced while doing the course thanks RigsbyMaster the machine and train your lab to know it inside out.
Get yourself, the lab and your G4 up to PFT Northern for a training course. Will cost but worth the money.
That's not true. What prep is different?there no point spraying skim as its not as fast as hand applying not even close with all the prep, leave the machines one coat plaster or mono where its twice as fast +
No masking taping up when hand applying ,dont matter any way cus machine will not beat hand applying for speed on skimThat's not true. What prep is different?
It won't curry forget it, ok you have a lab on the machine and you spraying how is that ever gonna be quicker than a lab mixing and a plasterer putting on?U reckon? I can assure u that a Ritmo spraying gypsum through a skim setup will smash it
what sort of sets you reckon 2 of you can do with the machine ? and if you can seriously be faster i would change staright away to machineU reckon? I can assure u that a Ritmo spraying gypsum through a skim setup will smash it
So your gonna do it all on your own ie set machine up, water, powde, load up then clean out and spray at the same time? Who the f**k your gonna get to flatten and trowel? Lol I would still loose you on my jack with a mega mixer, skimming is not for a machine end of, we have had that debate plenty of times on this forum. That original video was done years ago and I challenged anyone I would beat them to get that area on its to slow. Never been an issue putting on with a trowel that gets it flat and we all know multie is a two coat plaster.Why a lab on the machine? It mixes and sprays a bag every 5 minutes and holds 2 and a half bags
Don't forget you taped and filled all the joints and beads firstIf you look for currierplastering on youtube I have some videos of us spraying Mpfinish. Biggest hit we did was 230m2 in a school
