Is it worth the extra money for it? Doing my ceilings in soundbloc and wondering if it's worthwhile paying the extra to put acoustic insulation in instead of normal stuff. Wife's a light sleeper and tv will be directly below bed.
She goes to bed early and I stay up and watch porn n s**t.Would be cheaper to turn the TV off when you went to bed, would save electric as well
Sorry I couldn't resist!
Haven't used acoustic insulation
Used the sound boards with varying degrees of success
I feel sorry for the person putting the sound boards on the ceiling!!!!
Whats that?Cos they weight a bomb it is worth it but use resilient channels she won't hear you spunking then for sure
Steel channels that help with sound reduction buddy worth it trust me only two/three quid a length (3m) put in every 3/400mm and like above use a sound bloc insulation there's loads of diff brands so speak to do ever you buy from but in new build its double board to meet specWhats that?
Can't, if she comes down to check on me I'll no hear her and she'll burst in mid strokeWell I have done them with just the insulation and boards but no bars or rubbers @gps and you still hear sound so imo if you not going to do properly then don't bother just put your headphones on when watching playboy or whatever else you watch
Googled it and going to go with that, not going to double sheet as ceiling low enoughSteel channels that help with sound reduction buddy worth it trust me only two/three quid a length (3m) put in every 3/400mm and like above use a sound bloc insulation there's loads of diff brands so speak to do ever you buy from but in new build its double board to meet spec
Soundbloc insulation in between the joists as well?Googled it and going to go with that, not going to double sheet as ceiling low enough
Yes, should be good at thatSoundbloc insulation in between the joists as well?
Are you renovating your whole house Stu?Yes, should be good at that
Yes, done upstairs before I moved in start of last year and that's us tackling downstairs now. House is an absolute mess but starting to get there nowAre you renovating your whole house Stu?
Seen your other post thread
What are you suggesting, that old stu weighs as much as a motor bike ?Acustic boards 15 mm are between 42-47 kg each. If you decide to use them, search for imago' motorbike story first
Was thinking of the Mrs, cos he said will be downstairs watching tvWhat are you suggesting, that old stu weighs as much as a motor bike ?
At least 100mm in there as well stuart don't be a tight arse and put 50mm we know what you are like ..For the complete system to achieve maximum noise reduction you should always seal the edges with acoustic sealant (white book says so and is on every drawing) but to be honest hardly anyone ever uses it or has seen it it comes in sausage form or in a mastic tube it's white tube with blue on it be cheaper to move your to to the other end of room surely
That's 50mm. Been quoted £40 for a roll of acoustic 100mm that covers 12 m2
Yes I couldn't find the 100mm on net but thought I post you that one to show one I was on aboutThat's 50mm. Been quoted £40 for a roll of acoustic 100mm that covers 12 m2
This is best s**t on market stu 100mm and a 50mm on top...unless anyone else can suggest better...might not be the cheapest but not beaten on performance..I once used a sig version as it was cheaper I had to rip it all out and redo it was useless...defo go 150mm if possible bro
Are you insulating walls and floors as well to keep it warmer ?That's 50mm. Been quoted £40 for a roll of acoustic 100mm that covers 12 m2
He's using aerotherm I betAre you insulating walls and floors as well to keep it warmer ?
Worth doing while it's all smashed up
Concrete floor, putting underfloor heating inAre you insulating walls and floors as well to keep it warmer ?
I hate the knuagh earth batts next job is rock wool fo sureThis is best s**t on market stu 100mm and a 50mm on top...unless anyone else can suggest better...might not be the cheapest but not beaten on performance..I once used a sig version as it was cheaper I had to rip it all out and redo it was useless...defo go 150mm if possible bro
