Hi All.
I am looking at my building, the old render has been taken off and stripped down to bricks, in order to save some cash, I would like to ask if its possible to do away with the primer and instead use a sand/cement scratch coat, mixed with 3 in 1 additive and then the thin coat system can go on the scratch sand cement ?
I understand from my little research that manufacturers will not provide warranty if thier primer is not used.
The setup we are thinking of going with is as follows on the brick wall.
Star contact - white and has fibres is the base coat.
Final top coat
For the timber frame
Render board - 10mm which already has fibre mesh on it.
Baumit Primer
Top coat 1.0mm grain
Thanks in advance.
Final top coat
Baumit Primer
Thanks in advance.
