1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
Keeping the character
Discussion in 'Video Tutorials On How To Use The Plasterers Forum' started by Nicholas8323, Jan 31, 2018.
  1. Nicholas8323
    Nicholas8323 New Member
    Hi,
    A lot of useful information on this site I’m finding it very useful. I’d like to ask a question if I may. We are doing a barn conversion at the moment using traditional materials where we can. Lime render plaster on stone walls etc. Inevitably when converting the building like this there will be some new stud walls built . Now I fully understand that you can use traditional lath and lime plaster to create these walls but this isn’t a route that I have decided to go down. the walls are stud work with plasterboard and I’m trying to keep the character by getting the finish right on these walls. I’m using the trim tex rounded bullnose corner beads which are giving a nice rounded soft edge but my question is, when plastering these boards how or what is the best way to keep some character making it a good finish but a more grainy and imperfect one rather than the super modern ice rink flat.
    Any advice and opinions would be greatly appreciated.
    Thank you, Nicholas
  2. JessThePlasterer
    JessThePlasterer Well-Known Member
    Skim the board, smooth and leave it. So it's still flat but matt and will have imperfections. I did this at my mates 500 year old cottage, looked nice when painted and not too cottagey but not too new either
  3. Topspread16
    Topspread16 Well-Known Member
    Did one about 15 year ago where customer wanted limelight sponged up on the Stone and block and bonding on the studs wasn’t for me at first but warmed to it once it was complete. Since bonding reduced the size of vermiculite it could be similar to what your after. Try different ways of finishing it on sample boards. Sponge it the Just as it’s going green a light spray and flexy trowel so it with be flat and smoothish but pitted at the same time.
    • Like Like x 1
  4. Vincey
    Vincey Private Member
    Chuck gear on and follow with a brush
  5. Builderboi
    Builderboi Well-Known Member
    Use one coat and sponge up
  6. Stevieo
    Stevieo Well-Known Member
  7. choppa
    choppa Active Member
    Throw some bonding in with the mix the rub with a fine sponge on last stage of troweling to bring the grains up.
  8. flynnyman
    flynnyman Private Member
    Show us what your trying to match up to?
  9. Dropsalot
    Dropsalot Private Member
    In the dark.
  10. vfr12
    vfr12 Private Member
    R50 or R 100 over painted surface if you want to match other walls in the house
    • Like Like x 1
  11. zombie
    zombie Private Member
    Sounds hideous!!!
    • Dislike Dislike x 1
  12. malc
    malc Private Member
    thistle universal is a grainy finish that can be applied to plasterboard. it is white in colour.
    • Like Like x 1
    • Agree Agree x 1
  13. robbiboy1970
    robbiboy1970 Active Member
    a couple of hand full of building sand in a mix with 10L (ish) thistle board finish ,,one coat and a soft brush from floor to ceiling ......when painted it looks like whitewash
    • Like Like x 2
  14. Nicholas8323
    Thanks for this. Just googled this as I didn’t understand. so the r100 r50 is a bridging cost so I could use a line render coatthen whitewash?
  15. Nicholas8323
    I alpreciate all the comments here all good stuff.
    I’ll try to post a photo tomorrow.
  16. Nicholas8323
    Cheers.
  17. vfr12
    Both r50 and r100 are finishing coats, very nice finegrain and uniform finish, which you can’t get with limewash.
    Still patchy.maybe if you zoom in you can see the grains. I can’t see anything on my phone:rolleyes:
  18. zombie
    Acknowledge new areas as new and contemporary & old areas as old!
  19. JDM0703
    JDM0703 New Member
    Does anyone know if its actually possible to match the rendering on the picture? I moved in after (I'm guessing) a vent had been removed and would ideally like to repair the patch rather than persuade all of my neighbours to change the rendering along a block of 10 terraced flats.
  20. vfr12
    Re render the whole bit
    • Agree Agree x 1
  21. JDM0703
    JDM0703 New Member
    There are 6 areas with this patch of rendering so that would require everyone in the block to agree to all of them being rendered, no other options?
Share This Page
