multi peeling off ?!
It's hard without seeing it in person and I'm sure your spread is as good as you say. I can't help thinking some of that looks like surface peel though.
That has more to do with mixing than anything else. My money is on dry multiuni added to wet plaster and probably bucket not scraped to the bottom . That has nothing to do with plaster coming off boards . Is this the second attempt to fix it or is one you are mentioning in the first post?
And we do mix old and new mix , but never for the second coat. Always clean buckets and fresh mix otherwise you end up exactly with finish like this. Mixer is cleaned after every mix too.
But to be honest, the plaster is the one I am shitting my self when I see it on the bottom of the bucket and only when you wash it. These black little bits are the devils s**t.
What's the flynnesters analysis of the picture then godfather ?
I take on board what the poster has said and the guys experienced and there is a problem with the plaster. You are so on the defensive you can't see what's in front of you, you are not prepared to see both sides of a story especially when it involves uni, I've lost count of your stupid reasons I could point them out but prefer to do it as we go along that's what you keep getting upset about, you think your being picked on or I'm having a go. I can assure you I'm not because if anyone else was so f**k**g biased to a product that I thought had issues and so did others I would question it I always have read my posts. The pictures are a s**t finish there is no mistaking that but I believe the problem was the plaster otherwise the questions would be different.
So that is a fully boarded room, why is multi being used anyway?
There's a clue in the name.. Board finish.
Always notice when posts are about render products that have discoloured or are not perfect or knauff airless is talked about you and "others " don't blame the gear ..others suggest ways to sort it or help the poster.
The first coat had set before the second was applied then the second coat was troweled up to late..thus the fact it starts to tear.
Tell him to stop watching porn in your yard and get on it at the right time.
That is correct now do you see what I mean?
or get off online skybet
No I don't , I seen render photos off well known members for instance,saying they got problem and the rest of them try to help and discuss it for the better of the poster ,weather they have done something not to spec or if the gear was used wrong is always the answer.
But when it's multi tbh makes me laugh everyone always expects a perfect day and as you know it can be anything that wasn't done right but that don't matter it's just straight to the gear is s**t off a lot of spreads.
Another possibility , but if the guys experienced it wouldn't be the case.
Warm breeze is the answer. Wouldn't have said this till I saw what happened in a hot climate with multi purchased in January. Blocking the Windows stopped the problem.
Dunno if it's relevant or not but flynny once told me plasterman is a G** and loves botty s*x
I got told that as well lol...i don't even know y people are coming out with other stuff tbh
