new system for bead fixing
This would be handy for dispensing the tape
With all jokes a side.... I have had it when you use clout nails and it blows the corner off on reskims so in that case I think it may be useful
Get an endorsement from bead or board manufacturer and it will sell , but spray contact adhesive would work better
spray contact adhesive for carpets, staplers for teachers, clouts for wood. BEADFIX TM for fixing beads.
adhesive formulated to stick metal to plaster board and brick.
slower though,i can tape faster than you can bed on, cleaner if i drop tape it wont dirty carpet even without dust sheet.
you can bead up in your slippers
If your abouts to skim its already sheeted, I can give you a guarantee on that tape. I 100% won’t by it. Lifetime guarantee that
i know what your thinking
  • new system for bead fixing
Think your missing the point , don't go around setting beads before skim , beed ( for jess) is cut to length and simply pushed into first coat so less time than taping a bead in place, with a much stronger fix than staples etc , no gaps under bead , full contact
on a reskim?
ok, the next skimming job we get i will film the process and put it up.
can i upload a video onto this forum?
Come on mate. You've invented black nasty with holes in it.
I just wish @John j would stop saying beed!! It’s BEAD!!
@Stevieo how are you not picking up on this?! I expected better from you
I do it to you because I think you might learn from it and become a good member of society eventually.
@John j is a lost cause.
why dont they move about in the wet muck
black nasty with holes is marmite on a crumpet
But it doesn't need to be? So far you've spent your time showing us it can hold up a stop bead in a nonsense way and hold up a weight. Your trying to sell a way of fixing beads and in 4 days you've been unable to show us the tape holding up a bead. Im with Lurpak this has got to be a wind up, noone can be this inept
But it doesn't need to be? So far you've spent your time showing us it can hold up a stop bead in a nonsense way and hold up a weight. Your trying to sell a way of fixing beads and in 4 days you've been unable to show us the tape holding up a bead. Im with Lurpack this has got to be a wind up, noone can be this inept
There is already a pic of it holding up a bead posted
Not that I can see? Other than the pointless photo of it holding up a stop bead in a way that you would never use the product
coke can could be green but
you can try out the concept yourself just use some decent gaffa tape, and tape some beads up.
same thing in principle and see how fast and clean it is.
So I don't need your shitty tape then? I'll just use inch wide bits of gorilla tape if I ever get the urge. Honestly you've done a f**k**g terrible job here. I give up, never buying this.
the secret is the holes in the tape the adhesive and the top layer but you can still see if its useful by trying it on a mock up.
thats it im gone.
No problem , fully bedded gives better stability , I'm Ott and tape over and trowel into first coat as well lol
If I didn't give a s**t and had an idle lab I might consider your tape but not over contact adhesive
