Leemac1988
Correct way to float and set with Hardwall....
Skim ceilings first
Then float and skim walls
Or vice versa
Skim ceilings first
Or vice versa
If you skim ceiling first before float side ceiling will crack lol... Float first tape ceiling Skim walls . The old school always put skerting in first and I still think it a better job. But today time is money. Nothing wrong in putting skerting after you can caulk them up for a perfect finishCorrect way to float and set with Hardwall....
Skim ceilings first
Or vice versa
No , loads of reasons whyCorrect way to float and set with Hardwall....
Skim ceilings first
Its a wind up , I hopeJust don't do the job, too risky.
But skirtings were fixed to timber plugs or grounds which is rare now though I still have my axe.If you skim ceiling first before float side ceiling will crack lol... Float first tape ceiling Skim walls . The old school always put skerting in first and I still think it a better job. But today time is money. Nothing wrong in putting skerting after you can caulk them up for a perfect finish
Mate , get the other bloke who's telling you to skim first to come on , but can you make it Friday night about 7 be great funCorrect way to float and set with Hardwall....
Skim ceilings first
Or vice versa
Yes 18hundred. You float you fix skirting you skim that best job. But not many do that these days time is moneyBut skirtings were fixed to timber plugs or grounds which is rare now though I still have my axe.
Hows the head lolEarly start, float walls, skim ceiling, skim walls.
Hows the head lol
There's a new tape out for thatFine mate. I’ve just attached it to a bit of string and letting it hover at about 10 feet.
vice versaCorrect way to float and set with Hardwall....
Skim ceilings first
Or vice versa
You still don't get my sense of humour lolDebate, what's there to debate.
Only your mum gets that ! Thats why she thinks your the best !You still don't get my sense of humour lol
How is that comment directed at you.You still don't get my sense of humour lol
Post seven , thought I said debate , actually said fun lol , my sincerest apologies sirQUOTE="bof, post: 1295672, member: 32554"]
Well it must do to him ! All a matter of opinion !it really does not matter.
left boot first or right?Well it must do to him ! All a matter of opinion !
if you skim ceiling first and it cracks at sides, float will cover cracks.If you skim ceiling first before float side ceiling will crack lol... Float first tape ceiling Skim walls . The old school always put skerting in first and I still think it a better job. But today time is money. Nothing wrong in putting skerting after you can caulk them up for a perfect finish
I find your attitude to be a touch lacklustre and tbh a bit disapointing, for a professor !it really does not matter.
Good question !left boot first or right?
Superdick y the xIf you skim ceiling first before float side ceiling will crack lol... Float first tape ceiling Skim walls . The old school always put skerting in first and I still think it a better job. But today time is money. Nothing wrong in putting skerting after you can caulk them up for a perfect finish
Can't understand what's up apart from skirts on first is old skoolSuperdick y the x
Was it cos no cavity so didn't want moisture transfer and real wood had "shape " so plasterer matched the skirt line
Makes sense .on the army housing they fit a rebated skirting first. packed out to make sure it is a straight line.
the rebate is to make sure that the correct thickness, about 12mm of floating coat is applied to the walls.
Cheers malc , noticed similar on current house , was confused as got several different shapes as some had been replaced over the yearson the army housing they fit a rebated skirting first. packed out to make sure it is a straight line.
the rebate is to make sure that the correct thickness, about 12mm of floating coat is applied to the walls. the clerk of the works can then check that the plasterer has not bell cast out to the skirting.
As you saidCorrect way to float and set with Hardwall....
Skim ceilings first
Or vice versa
