Fill the speakers full of unifinish?
Must try harderSit it on some foam.
Really can’t believe all the moaning that’s going on about the bass on the makita radio’s?? Lol.
Crank the f*kr up When your grafting i say!![]()
Must try harder
I will sell the solution to the highest bidder
Try putting it on the cil mate. LolIt’s cracking my ceiling mate![]()
Out of the corner, carefully now , don't want to get carried away but your actually on the right track , was that a guess?Keep it out of the corner, suspended from the ceiling with string and sky hooks?
1st clue , cos I believe you ,
Its out of the box
Again , not bad , but you were closer with being out of the cornerPut it back in the box, or make a box and put it back in?
LolLay it on its side.
You mentioned high pass filters , but they are complicated circuits for high quality control and inevitable sound distortion in the clipping field
Its going down hillCould reverse speaker connections on one side.
They be handy round the house whith Mrs and 3 girlsI don’t f**k about when it comes to decent tunes at graft. I just rock these bad boys!
Let's stick to only outside of the box
Take a break and try the other quizThinking?
You can Dial a friend but google won't help youThinking?
Spell checker? Did you say drinkingThinking?
Always drinking. Can always turn the volume down, that reduces the bass...fletcher Munson curve!Spell checker? Did you say drinking
That ones easierHow's the other quiz going , why wet the wall ?
Never come across fletch but at a snap guess I'd say he's on the same wavelength but loosing more volumeAlways drinking. Can always turn the volume down, that reduces the bass...fletcher Munson curve!
Actually that turned out to be one hell of a clue ( my answer )Never come across fletch but at a snap guess I'd say he's on the same wavelength but loosing more volume
Fm?Actually that turned out to be one hell of a clue ( my answer )
No , my answer I'm assuming his theory has something to do with,,, too long to type but produces the same result but by less volume , along the lines of speaker sounds in corner of room and middle of wall , effect but he's staying in the same spot and altering wavelength by volume , air dampening etc etc , how's the other quiz going , assume you have the answer
