Radio.
I will sell the solution to the highest bidder
No. I will sell you the solution :D
This is the current solution
34245
Keep it out of the corner, suspended from the ceiling with string and sky hooks?
Out of the corner, carefully now , don't want to get carried away but your actually on the right track , was that a guess?
You mentioned high pass filters , but they are complicated circuits for high quality control and inevitable sound distortion in the clipping field
Always drinking. Can always turn the volume down, that reduces the bass...fletcher Munson curve!
Never come across fletch but at a snap guess I'd say he's on the same wavelength but loosing more volume
No , my answer I'm assuming his theory has something to do with,,, too long to type but produces the same result but by less volume , along the lines of speaker sounds in corner of room and middle of wall , effect but he's staying in the same spot and altering wavelength by volume , air dampening etc etc , how's the other quiz going , assume you have the answer
