Thats a great post, I'm a chippy! Am I correct when setting battens for EML that the batten only needs to thick enough ie 12mm or less to allow the render to push through in order to grip on, when the need for ventilation is negated by various vapor/waterproof barriers.
Are you the chippy on site that tries to out smart the plasterers.Thats a great post, I'm a chippy! Am I correct when setting battens for EML that the batten only needs to thick enough ie 12mm or less to allow the render to push through in order to grip on, when the need for ventilation is negated by various vapor/waterproof barriers.
I believe you'll find that an air gap is to be maintained according to building regs. nowadays.Thats a great post, I'm a chippy! Am I correct when setting battens for EML that the batten only needs to thick enough ie 12mm or less to allow the render to push through in order to grip on, when the need for ventilation is negated by various vapor/waterproof barriers.
You're not kidding Pete, many ups and downs. Unfortunately too many downsFair play Andy mate never seen this thread
Bet you thinking same , f**k where did ten years go
Ahh ok will check that, in the wake of Grenfield air gaps as a regulation might get revisited.I believe you'll find that an air gap is to be maintained according to building regs. nowadays.
