ImpossibleThat can be anything between 40-60m2. If your name is one coat wiz that’s 100m2
30 to 40 mWrong question? You should ask how many m2 you doing per day?
Not if you have 60m2 openingsImpossible
When you one coat u put s**t loads of water on170m2 is what I got paid for that day.
In reality it was a 140m2 lay on with 30m2 of measure through windows and doors.
Rooms had no ceilings, grid only coming in afterwards.
Long walls with a grid ceiling at 2.5m.
Slow fellas are gonna hate but anyone decently quick knows a 100m2 in a day onto the right areas is very doable.
It's not much harder to imagine another 30m2 in that day.
Peace out you slow c**ts.
How does it dry outJust go on a little bit thicker than normal andy nice and flat.
I don't use s**t loads of water, I try and use as little as possible until the very end
Every time
Two weeks in the priory mate.How does it dry out
How does it dry out
How many bags a setRich don't be jealous mate, I'm young and have been doing this day in day out on sites since I was 18, I'm 27 now. I don't render or anything else I literally skim boards, occasionally skim over existing plaster/minor bonding work.
That 140 is the best I've ever done.
I do about 80 or 90 a day
Lurpy went out then.. you came in![]()
How many bags a set
U use speed skim and what trowelLooks better than most lads two coat work mate, seriously.
Miles better than anything rich has ever produced.
You will do better when your feeling better about yourself30 to 40 m
names not richRich don't be jealous mate, I'm young and have been doing this day in day out on sites since I was 18, I'm 27 now. I don't render or anything else I literally skim boards, occasionally skim over existing plaster/minor bonding work.
O he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**tTwo weeks in the priory mate.
names not rich
Not jealous, been there done that, learnt my lesson from slogging it all day long. You wasn’t even born when I started on the trowel.
I like your come backs, they are fun
Your plastering all your life and you ask questions like that you stupid c**t.I’m sick of your shite you insulted me here beforeGo and get the clemrope and put yourself out of your misery.U use speed skim and what trowel
How many bags a set
O he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**t o he's a c**tYour plastering all your life and you ask questions like that you stupid c**t.I’m sick of your shite you insulted me here beforeGo and get the clemrope and put yourself out of your misery.
140 = 14 bags u c**tRich don't be jealous mate, I'm young and have been doing this day in day out on sites since I was 18, I'm 27 now. I don't render or anything else I literally skim boards, occasionally skim over existing plaster/minor bonding work.
A bit u had a bad day if u just put 60meter on140 = 14 bags u c**t
Andy g
It's very rare I work by myself mate, normally 4 of us.
3 or 4 lads throwing it on and one lad with a speed skim either going behind or dropping back is another way to hit a decent size wall and have control of it pretty quickly.
The trick with that is the lads putting the plaster on don't have to be good, the lad using the speed skim does though.
We try to fill a blue water barrel we cut in half to the top with plaster and split it between us in answer to how much plaster I use.
I.ve met 20 year old blokes who talk like their the b*ll***s and are rough but fast@The_one_coat_wizard you actually make a good point. I’ve met 35 year + blokes who are shite.
You’re either rough or not. You don’t start rough then 10 years later find the lord jesus christ and change your ways. You’re rough for life and probably rough in other aspects of your life ie; cash flow, parenting etc
I’ve tried to tell myself not to care as much. But it’s not in me. I’ve gone back and pva’d n re-skim stuff before without a customer knowing or caring just because I wasn’t happy with it.
And I know how stupid that is believe me, but I can’t switch it off.
Might aswell spray it on
Fast and quality just don’t go together
