Does skim go off any quicker by using speedskim just toying with the idea of getting one ???
Hi mate - The just want to clarify the plaster doesn't go off any quicker but the reduction in particle vibration when using Speedskim mean you can get your second coat on straight away. It does speed up the overall process - with the potential to get more hits on if you want. After you have applied the Speedskim on the second coat the plaster sits really well so you can relax a bit more - take a breather. If you dont want to get more on and you just want a much easier day with less aches and pains that's what it gives you.
Plasterers need the right tools for the job and plastering techniques are slowly changing. We feel the vast majority of Plasterers are keen to accept change and like comfortable professional equipment to use.
The Speedskim is making life a far easier for many Plasterers - highest grade material go into the manufacture, specific for purpose with the correct combination of rigidity and flexibility for skim coat, backing plasters and renders.
Affordable to the Plasterer, efficient and versatile with extremely economical blade change. Comfortable by design, Universal pole attachment for ceilings.
Coming soon are new finishing blades for different applications and surface finishes - all completely compatible with existing handles.
So for anyone thinking of purchasing a lot of thought and design is going into the product range. At the same time all made in the Great Britain supporting British jobs :RpS_thumbup:
Hope this is helpful - if you need any info just give us a shout..
Scott
