can you still use the same mix if you rule the 1st coat??........i normally knocked the gear though again with some water for the 2nd coat if im using the same gear
How many metres do you do before you rule it, I tried it and it tore the **** out of it
if I did not love you before I do now,Thanks My new BFFWhy will it suit bad plasterboard if you can only lay on 3mm anyway, I've never met anyone too 'weak' to flatten in surely that's the easy bit and you must be pretty shite if you can't keep an angle straight when you're skimming
apart from that good post
I have finally used mine, its handy and labour saving especially useful for large ceilings..I think the weaker plasterers as in not able to flatten with a trowel properly will find it essential, its another useful tool overall ,it will suit bad plasterboard work and help eliminate wavy lines on the angle..
Weaker in the ability sense,My computers crayons are broken so I could not........Cant say av met many plasterers with noodle arms.......................:RpS_unsure:
You teach them backwards John or itd be pointless laying a wall on because they can't finish it?
are you sure you started in '87 not 2007?
which was the soonest ,it was the other...You teach them backwards John or itd be pointless laying a wall on because they can't finish it?
Its been tried , some of the jury are off sick, I am failing to get it yet really, but some people love it, not really been over busy either, just skimmed bits and bobs since xmas...Have you used your plazzy trowel yet johno?
The problems started with the outrageous metreage claims Steve. Also the methods you use don't comply with any product guides for BG finish plasters which are obviously the most commonly used, this could lead to problems at some stage.
The truth is IMO these tools do have a place and have been used for many years (cavity closers), but if you are going to use the "correct" methods of application and have the skill to put on neat and tidy and don't try throwing on more than you can cope with their uses are limited. With spray applied finish they would probably be more or less a must have tool.
By the way I did buy one just to be sure and do use it from time to time but it's no miracle tool.
Can I suggest then, that you make the bit that you're fingers sit in deeper.
Hi mate - we have got other products lined up in 2013/2014 and improvements like these are being considered :RpS_thumbup: The blade slot wont change so anything we produce will always be compatible.
I think they say improvement is a journey - not a destination
i think the ally that holds the plastic blade needs to be wider,as I'm sweeping it over the wall my fingers are resting against the wide plastic making the plastic bend,perhaps the plastic needs narrowing and the ally needs widening IMO, hope that makes sense.
Hi mate - you are right the problems did start with the metreage claims. We did set our self up for a bit of stick in hindsight. We have (and you may have read in one of our other posts) conceded that the 100% metreage claim was unrealistic. We were very keen (over keen) at the start but did feel this was a true statement of the products abilities at the beginning . We have listened to a number of members including you over the last 12 months - and amended these claims to be more realistic on our website and ebay listing. Now when answering members questions we are able to draw upon the true customer comments and feedback we have received over the past 12 months to give the correct information. Lee and I have grown with the product if you know what I mean.
Regarding British Gypsum - they are using Speedskim in their training academies (they invited us to demo the product at one of their facilities) and so they dont have a problem with using the product on their materials. In fact quite the opposite.
We recommend how to use the tool based on the experience of using our self and other professionals we have feeding back to us on various material applications. We do stand by the fact that it can increase your output (depending on certain conditions and your technique) and make your day easier solely based on what our customers say.
Speedskim is a comfortable, versatile tool with economically replaceable components. It can be used in a variety of plastering and rendering applications and a lot of plasterers find it a great benefit.
In the process of promoting our products we do take notice of any constructive feedback and also constructive criticism. Both are taken on board seriously.
I think its fair to say there isn't a single product on the Forum that everyone swears by..
I hope this sounds reasonable and sincere :RpS_thumbup:
Scott
Wise words Grasshopper.
BTW how much are the poles?
Hi Scott that's a very reasonable reply and I think you're doing the right and decent thing in reigning in the meterage claims.
I wasn't suggesting that it was unsuitable for use with BG products because it clearly is, it's just that the methods that Steve Currier recommends are not those set out by BG for use with their products e.g. one coating with Multifinish and sponge floating....well, any of their finish plasters.
As said I've used other products for years to do exactly what I consider the Speedskim to be suitable for but the handle on yours is much more ergonomic than the bit of batten I had screwed to the closer.
I would also add that I've done a lot of rendering both internal and external and know how a rule needs to behave and not even the thinner lightweight alloy featheredges are suitable at anything over about 1.2m IMHO, let alone something as flexible as the Speedskim. The fact that lots of guys are using it for that purpose really doesn't mean they're suitable, as the majority of plasterers I've come across in the last thirty years are just interested in making a quick buck and not in the standard of work they leave behind them.
If I were you I'd say it's a good tool for flattening between coats and maybe a quick flatten of the top coat for the less able spreads and perfect for the initial flattening off of Thistle Spray Finish. I reckon you'd still sell loads and would never be accused of trying to put it across as some sort of tool for all occasions.
Wishing you continued success and all the best
Andy
Tried out a speedskim today as one of the lads working for me has one. I followed his method which was lay on, speedskim, lay down, speedskim let it pick up a little then wet cross with my usual trowel and finish with a flash with a plastic trowel and I found it took a lot of the work out of flattening and the finish looked great so will be buying one:RpS_thumbup: what's the offer coming up next week and how much please
Scott
the forum international correspondent is back...............how's it going marra??
