essexandy
The Lake Governor
How old were you when you retired mate?Why would anyone want to film plastering, it's throwing a bit of s**t up the wall ffs.
Their 15 minutes of fame mate !Why would anyone want to film plastering, it's throwing a bit of s**t up the wall ffs.
you assume I do old masonry in one coat? I doesn't work mate. Unless you're doing the facing side of a feature wall that was built well. With old brick there's only ever one side that can look clean. The back will always be s**t. When you try and plaster the back, or just dodgy brickwork in general, some areas will end up too thick and will drop out and if it doesn't, it will shrink excessively, likely delaminate and crack. It only takes one wall in a plasterer's career to know this. Thing is, I know this by experience, not because someone said so.See you're just showing your lack of knowledge again.
If you're going over rough brickwork you shouldn't even be trying to get it right in one visit. The correct process is render, float and set. This was standard practice way back in time. I've done a fair bit of it on refurb jobs, an old pub being converted into residential springs to mind.
When applying the render coat you can cover vast areas as you're only knocking it into shape and there's no floating, just dragged. This is then left to cure.
The floating coat is then even easier than normal because you've already dubbed where needed.
if you have a good hod carrierSo with the two combined you should be able, depending on areas, to cover around 45sqm. per day without killing yourself or ending up a cripple.
No you don't need a good hod carrier or any labourer to achieve the meterage I've mentioned if you know what you're doing and have a good work ethic.if you have a good hod carrier
pretty much every resource disagrees with you mate. Try and look for it online yourself. No one claims they can do 70sqm daily by themselves. Most resources state a good plasterer should be able to average 20 - 30 sqm/day. I asked around with some other plasterers and none have told me it's realistic or wise.No you don't need a good hod carrier or any labourer to achieve the meterage I've mentioned if you know what you're doing and have a good work ethic.
Anyway I've wasted enough words on you now seeing as you don't listen and constantly disbelief that others are capable of that which you are not.
Will you just shut the f**k uppretty much every resource disagrees with you mate. Try and look for it online yourself. No one claims they can do 70sqm daily by themselves. Most resources state a good plasterer should be able to average 20 - 30 sqm/day. I asked around with some other plasterers and none have told me it's realistic or wise.
Until you send me a video of someone doing it, I'm just not gonna put my confidence in your word. Maybe one day I'll come to the UK and some of you can show me then. But I'm not going to believe anything based on the drivel of some random boomers on a mediocre (at best) internet forum. Maybe I'm wrong though; in which case, if you can empirically prove you're right, I'll be ready to apologise. Cheers and all the best
only if you send me a video of you doing 70sqm in a day and float it within 3mm tolerance. Until that time, I'm afraid you're stuck with me. You always have the option to leave or better yet, turn off your computer and go outside. Too much computer time will make you miserable. Good luck!Will you just shut the f**k up
Don't, you'll regret it, you'll be the talk of the town at your local A&E.Going for 72 today
actually, a lot of people seem to agree. I posted some screencaps earlier in this thread, go have a lookQuote
"The plasterers forum is mediocre at best"
Some Belgian c u n t from Mumsnet 2024
actually, a lot of people seem to agree. I posted some screencaps earlier in this thread, go have a look![]()
nice cope mate; it's like that bloke said: this used to be a nice community years ago and now it's just a couple of mental retired boomers sucking each other's dicks pretending they still matter.A lot ?
Or 3 bitchy r e t a r d s?
Planned to stop site work at 50 but carried on as money was good, then was given a project with guaranteed wage for a couple of years that I couldn't refuse.How old were you when you retired mate?
What do you want, you live in a different country using different products with a different work ethic.nice cope mate; it's like that bloke said: this used to be a nice community years ago and now it's just a couple of mental retired boomers sucking each other's dicks pretending they still matter.
Every time I've come here for help and guidance, what I got was abuse, trolling, navel gazing and general r3tardation and I'm all for it, but again, Reddit would be more appropriate for that. This is a plastering forum and even though you have a lot of experience, the trades are always evolving. But it seems that some people prefer to remain stuck in the past. The whole point of being old is to offer guidance to the newer genertion. But that doesn't mean your way or the highway. It means that you put yourself in the position of the youngsters and help them achieve what they would like to achieve. Not what you want them to achieve. A lot of old people get this wrong and that's why no one likes you. A little empathy would go a long way. But I'm preaching to the walls I know.
How? No one else uses my system. I have no choice other than getting my own jobs. Which is why I was here. I already told you that at the meterage I know I can maintain, which is a conservative, realistic estimate, I have a good wage I'm happy with. But every time I say that, you just roll your eyes. How about you just show some encouragement and give me tips and tricks to help me make it work.My suggestion of staying on day work until you gain experience to price your own systems didn't help.
never done that, so that will be something new to learn. But thanks for the feedback; much appreciated!Put screeds on it'll run straight then
Pick out high point along wall string line helps on long runs start there with thin screed. Distance next screed to longest straight edge you use. You can get long rigid aluminium box sections from steel merchants. That what I use on large floor screeds too. Fill in and rule up wall will be BANG on.never done that, so that will be something new to learn. But thanks for the feedback; much appreciated!
Is there a method to placing the screeds? My guess is that you have to make sure your rule can bridge the distance. Anything else to be mindful of? for example, in case you're working on a MASSIVE wall?
Don't tell him how many metres you can do smudge, it'll end in tearsPick out high point along wall string line helps on long runs start there with thin screed. Distance next screed to longest straight edge you use. You can get long rigid aluminium box sections from steel merchants. That what I use on large floor screeds too. Fill in and rule up wall will be BANG on.
You're going to need 3 screeds BANG on to cayr along wall touching 2 screeds with straight edge reaching the next one to keep it true to the ends.
Early finish today my arm was hurting after 50m2Don't tell him how many metres you can do smudge, it'll end in tearsjust say 14
I have a floor screed rule, but why do you use it here? You're not scraping the wall but rather "floating" it with the rule?You can get long rigid aluminium box sections from steel merchants.
only 50? I know guys that can do 70 without even tryingEarly finish today my arm was hurting after 50m2![]()
It's Friday, everyone deserves an easy day now and againEarly finish today my arm was hurting after 50m2![]()
Once you've got a few screeds on its easier to use them as a guide to take excess off further screeds bottom to top before floating them in then check for straight with the rule. I've got a couple of aluminium box section screeders ones 3m long I lay across screeds to check they slide up the plumbed screeds to make sure they're all laying true. Then fill in the gaps using the screeds on wall and screeder to take excess out and float up.I have a floor screed rule, but why do you use it here? You're not scraping the wall but rather "floating" it with the rule?
ah yeah I think I can picture it. You're right, a floor screed rule slides much easier over the plumbed screeds. A regular straight edge would dig into them, likely destroying them. Since floor rules work on floor screeds, it seems logical that they would work well on a big, high suction wall as well.Once you've got a few screeds on its easier to use them as a guide to take excess off further screeds bottom to top before floating them in then check for straight with the rule. I've got a couple of aluminium box section screeners I lay across screeds to check they slide up the plumbed screeds to make sure they're all laying true. Then fill in the gaps using the screeds on wall and screeder to take excess out and float up.
Clearer ?
video proof is obligatory yes, alwaysIf anyone says yes.....
Are you you going to ask for a video for proof?
is it possible to floor screed 30m2 in a day by yourself? 30mm thickness
I did 50mm, 30m2 in 3 short days. So maybe 30mm should be manageable in one long day and with good prep? In case I need two days, is it possible to make an overlap if you add cement? I've only done earth screeds and they take a long time to dry, so you can always continue the next day where you left off. But I don't think that works when you add a hydraulic binder right? Or is there way to patch sections together? Maybe insert a mesh at the border at the end of the first day?
He's not retired neither am I . I'm sixty six. You asked about sand and cement, not lime.you delusional thinks-he-know-it-all has-been
enjoy retirement
Doesn't make sense to me though. Bag of cement costs 10€, bag of quicklime costs 18€ (but has almost twice the density of cement)He's not retired neither am I . I'm sixty six. You asked about sand and cement, not lime.
Houses here aren't made to breath it's all about money , that's why cement took over from lime.
