tapit
yes mateI.m confused at first I thought it was a tape that you put on instead of beed but is it tape you use to stick beeds on with
It won’t re-emulsify the pva so will just pull the pva off.
Bet I could do it quicker with clouts on board then using tapeSo it’s a system for perfectly boarded angles. Bout as useful as a cock flavoured lollipop
how many clouts do you use?Bet I could do it quicker with clouts on board then using tape
not with you on that one?
probably similar to a good quality scrimCome on ffs! just cut to the chase how much is it?? Lol
i think i could stick three pieces of tape quicker time after time, cut stick, instead of hold, hammer ouch .
most new build and domestic skim angles are not far outSo it’s a system for perfectly boarded angles. Bout as useful as a cock flavoured lollipop
As few as it needs till its tight allway up corner. . How longs each strip of tapehow many clouts do you use?
as long as you cut it,i use one strip horizontal agross bead about 75mm longAs few as it needs till its tight allway up corner. . How longs each strip of tape
That wouldn't hold beed enough for meas long as you cut it,i use one strip horizontal agross bead about 75mm long
One more point, would it be as stable wit laying on in comparison to these other diy methodsmost new build and domestic skim angles are not far out
it also pulls bead in tight no wobbly slack
i meant the length,four strips max on 2,4 bead at same centres as BS for mechanical fixingThat wouldn't hold beed enough for me
as good as or better than all other systems and so simpleOne more point, would it be as stable wit laying on in comparison to these other diy methods
you have two slow systems,this replaces both and is quicker and no sore thumbs,you could however use the tape to wrap around your thumbs before hitting that tiny clout into rock hard concrete
Email me [email protected] and I will take a closer look
ok, i will send over some drawings prob tomorrow now. cheersEmail me [email protected] and I will take a closer look
How thick is it, any concern over the void created on surrounding bead area , would consider contact adhesive perhaps , just spray inside of bead if reveals are checked and press onas good as or better than all other systems and so simple
i am hard of hearing unfortunetly, its still in research stage but i would envisage less than fiver which would be enough for typical three bed houseAre you Mutt & Geoff!!!!! Hooooow muuuch!!
0.2mmHow thick is it, any concern over the void created on surrounding bead area , would consider contact adhesive perhaps , just spray inside of bead if reveals are checked and press on
faster and cleaner with no waste or empty cansHow thick is it, any concern over the void created on surrounding bead area , would consider contact adhesive perhaps , just spray inside of bead if reveals are checked and press on
Free loading f**k*r lolEmail me [email protected] and I will take a closer look
Send me a roll to try I’m genuinely intriguedi am hard of hearing unfortunetly, its still in research stage but i would envisage less than fiver which would be enough for typical three bed house
How much is on a roll then?i am hard of hearing unfortunetly, its still in research stage but i would envisage less than fiver which would be enough for typical three bed house
i only have small sample amount but i will give some out to try if and when it takes off.Send me a roll to try I’m genuinely intrigued
still not finalised roll sizes but your feedback as to size and price appreciatedHow much is on a roll then?
