smoother09
Any good for bellcast beads
People will always find ways to f**k you up the bastardsBuilders merchants don’t do it mate. It’s only wickes and b&q wallys! Lol
You sent them a stiffly worded letter.Drives me insane that. Have fired off a rather heated email to wickes complaints department about it
You fcuking animal.
you and many others are still using outdated methods to fix modern materials.Take your shitty bead Idea and do one I stick all my beads with gear dry wall or finish and f**k**g level ain't gonna do it with that sticky s**t! What a f**k**g pathetic Idea do you work on till at b&q and looking for a break in life? Take your idea to Clinton cards might be good for sealing envelopes![]()
I.m out . This is a piss take or your mates a pillockyou and many others are still using outdated methods to fix modern materials.
if it works for you it's good.
my mate still mixes with a stick and he is quite happy.
Yeah, you fcukling EMAIL.
Nowt wrong with stick and pogo , never break down and don't get nicked , let the mix sit for 5 min before you start is easiest , I've only gone electric in last 10 y due to old age , my dad ( 79 ) still does the odd wall or ceiling and only uses stick and pogoyou and many others are still using outdated methods to fix modern materials.
A customer asked me if I got old stick.Nowt wrong with stick and pogo , never break down and don't get nicked , let the mix sit for 5 min before you start is easiest , I've only gone electric in last 10 y due to old age , my dad ( 79 ) still does the odd wall or ceiling and only uses stick and pogo
Modern materials? Angle beads just come out have they? Must of missed something in my years lolyou and many others are still using outdated methods to fix modern materials.
hook ons don't work on reskims to existing plasterhook ons beat you to it for decent corners without the work of taping and cutting bits away and people still dont like them, for wanky corners wont work like hook ons wont so people will carry on using stiff gear
think he is a double glazing salesman trying to make a bit on the sideHow much is on a roll then?
A company already make a corner bead specifically for plasterboard. Can't remember what it was called but the bead had little spikes all the way down it. Pushed onto the corner and held instantly. Even that didn't take off massively and worked spot on. If I worked on site I'd use them every time but only skim onto board probably 10% of the time.yes mate works on boards and faster than stapler.
no loose beads or trying to line up holes with staple.
also you can't staple a hard wall but tape does both.
if you can hold beads in place with scrim your a magician.Give up reading after a page and half, it’s a wank idea, if i wanted to tape beads on i’d Use scrim which I already have on the job. What happens if the tape gets wet? If my nails get wet I can still pick them up and use them easily.
Yes they do, no bother at allhook ons don't work on reskims to existing plaster
too late,I'm encouraged already!Don’t encourage him
do you do much reskimming over old finish?A company already make a corner bead specifically for plasterboard. Can't remember what it was called but the bead had little spikes all the way down it. Pushed onto the corner and held instantly. Even that didn't take off massively and worked spot on. If I worked on site I'd use them every time but only skim onto board probably 10% of the time.
Loads more comments just appeared... I can see above now they are called hook ons. Great product
I used to fit double glazing when it was hardwood n ally.think he is a double glazing salesman trying to make a bit on the side
Come up with ready mixed finish that stays wet when you put lid back on £££££££££££I like your enthusiasm mate but your solving a problem that's already fixed (for square reveals) and still people aren't bothered and doing it the old way, this tape wont break the market....come up with something like halftime and youd have more of a chance but sadly that's already been done
We’re plasterers it’s a wet trade. I can hold beads onto plasterboard with scrim no bother. I haven’t read all the posts but I can tell you now nobody will be pulling themselves off over it. Most spreads would buy a roll to try, that would be the only roll. Buttering on beads goes back as long as buttering bread. Invent roll on lurpak or floraif you can hold beads in place with scrim your a magician.
why would you let your tape get wet?
that's like putting a half open bag of cement in the shower.
You.d need a steam roller to roll on lurpakWe’re plasterers it’s a wet trade. I can hold beads onto plasterboard with scrim no bother. I haven’t read all the posts but I can tell you now nobody will be pulling themselves off over it. Most spreads would buy a roll to try, that would be the only roll. Buttering on beads goes back as long as buttering bread. Invent roll on lurpak or flora
