D
Deleted member 29624
Guest
Ready for a bashing but want some advice anyway...did a hall, stairs and landing a few weeks ago and had a call saying one of the walls is wavey when the light shines down it, been and looked and customer is right, so said will pop after work and re-do it...rest is fine but I did that wall 2 coats from 1 bucket and its the only one not right, will that be the reason? Putting wet on wet moving the first coat around when trowelling it up, first time ive had this so after a bit of insight. Customer says it looks fine with the lights on just when the daylight hits it....did I maybe put water to it to early?
