Dr.B
The biggest problem when doing float and set is when door linings are on the piss. Otherwise I find it pretty easy to get walls flat and plumb despite block work being bad because you set all your beads around windows and externals perfect and can rule off from them. I always check the internal corners with a level and all is good. But margins need to be looked at too because if something is pissed, like a door or a window opening in a narrow space and you make things plumb then it’s going to look s**t so you have to compromise and just line things up aesthetically so it looks good.
